Mikuni BS34 problem
  • markovis07
  • markovis07's Avatar Topic Author
Mikuni BS34 problem
10 Mar 2013 09:37 - 10 Mar 2013 09:38
#576315
I'm proud owner of 1984 GPZ750.
Bike is in stock, except for the L&W 4-1 exhaust. Stock airfilter also.
All jets are stock, main is 110.
Bike used to run well, and rev to the red zone with no problem.
I had a problem with choke, and removed float bowls, cleaned all circuits.
I discovered that float level was WAY high, and returned floats to 18,6mm (factory). Did not mess with mixture on any other adjustment.
Returned carbs on bike. Engine starts perfectly, choke working, but she won't rev over 5000 in any gear. Even in first. Works well until that, and then like it hits rev limiter. Tried to put petcock on prime, nothing. Replaced spark plugs, nothing. Tried to pull the choke, nothing. Tried to remove airfilter element, even worse!
Some people suggest me to put larger main jets. As i know main jet only affect from 3/4 of throttle to WOT. My problem starts to happen on only one third.
Also, if i put WOT, engine dies during driving. Putting throttle to half, returns me to "rev limiter", and on quarter bike works normally.
Help needed. :(
Maybe I should take up a cheaper hobby. Horse racing for example.
Last edit: 10 Mar 2013 09:38 by markovis07.
  • Steve1986
  • Steve1986's Avatar
Re: Mikuni BS34 problem
10 Mar 2013 10:00
#576318
im not an expert but it sounds lean or you have a vacuum leak did this happen after the exhaust change or was it sudden ? what color are the plugs burning
1982 kz1000J
Miles-6700
  • Old Man Rock
  • Old Man Rock's Avatar
10 Mar 2013 10:06 - 10 Mar 2013 10:08
#576319
Key notes to LEAN condition..... "Bike used to run well, and rev to the red zone with no problem. " & " discovered that float level was WAY high"....
Maybe this will help you diagnose your symptoms....
Basic rule of thumb for 4-1, pods (I realize you're using air box), non stock configuration jetting etc....
Follow this link for BS 34 re-build/tuning... One of the best write ups w/images I've come across... ;)
BS-34 Rebuild....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 10 Mar 2013 10:08 by Old Man Rock.
  • markovis07
10 Mar 2013 10:17
#576320
The exhaust came with the bike. Never used any other.
Spark plugs looks okay. Dark brown.
10 Mar 2013 10:49 - 10 Mar 2013 13:33
#576327
If not already done, would assure that the ignition timing advancer is properly functioning and not stuck in the idle position.
markovis07 wrote: ...discovered that float level was WAY high, and returned floats to 18,6mm (factory)....(
Would also perform the clear tube test on each carb to assure correct fuel levels.
"Float height" measured with carbs on the bench is not a reliable manner to assure correct fuel levels.
So long as fuel level is within specs, it doesn't really matter what the measured dry float height happens to be.
Good Fortune! :)
Last edit: 10 Mar 2013 13:33 by Patton.
  • Old Man Rock
10 Mar 2013 13:15
#576347
Think you missed the point....
Just because the 4-1 exhaust was on when purchased doesn't mean it was jetted correctly... ;)
Case in point, float level was off thus extra fuel to compensate for the lean condition of the exhaust...
You adjusted float levels to spec now issues (more air than gas).... ;)
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
The following user(s) said Thank You: wireman, turboking
  • turboking
  • turboking's Avatar
10 Mar 2013 13:44 - 10 Mar 2013 13:44
#576350
Old Man Rock wrote: Key notes to LEAN condition..... "Bike used to run well, and rev to the red zone with no problem. " & " discovered that float level was WAY high"....
[url=http://kzrider.com/filebase/doc_download/508-mikunibs-
cvcarburetorrebuildtutorial]BS-34 Rebuild....[/url]
great rebuild/tuning article :side: thanks for the link B)
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
Last edit: 10 Mar 2013 13:44 by turboking.
  • mtkawboy
  • mtkawboy's Avatar
10 Mar 2013 19:38
#576402
My 82 GPZ750 has run all stock jetting and needle settings since it was brand new with a $90 RC Engineering 4-1 pipe I put on it when it was a month old. All Ive done is uncover the mixture plugs and richen them 1/4 turn plus synch them. Still runs perfect and Ive cleaned the carbs several times due to plugged pilots jets. Are you absolutely sure youre measuring to the correct point on the carbs for float height ? Have you tried running it on the manual prime position, perhaps the diaphragm could be going bad in the vacuum petcock ? You might have also cut an airbox boot or something removing & reinstalling the carbs. Good luck with it.
  • baldy110
  • baldy110's Avatar
10 Mar 2013 21:11 - 10 Mar 2013 21:36
#576426
Are you trying to run it without the carbs attached to the air cleaner?
Last edit: 10 Mar 2013 21:36 by baldy110.
  • markovis07
11 Mar 2013 03:02
#576466
No, the carbs are hooked to the airfilter housing.
I guess you're right, that the high fuel level compensated for the small main jet.
I've got good fuel flow, petcock works ok in all positions.
  • baldy110
  • baldy110's Avatar
11 Mar 2013 14:27
#576510
How do the diaphrams look.
11 Mar 2013 14:40
#576513
Hang on a minute. The bike ran well with the stock jetting. (so leave the jetting alone for now). There was an issue with the choke so you pulled the bowls. While you were in there you fiddled with the float height and set it to " floats to 18,6mm (factory). " What the heck kind of float height measurement is that supposed to be??? Trying to set the "Float Level" is an exercise in futility unless you go back and correctly set the FUEL level using the clear tube method as described in the Kawasaki Service Manual and on this site. You really need to do the clear tube process to CORRECTLY set the height of the FUEL. Otherwise, if the fuel level is too low you can change jets until the cows come home and not solve the problem because the engine cannot run at high rpm if there is not enough fuel in the carb bowls. Ed
