Kz550 tk throttle shaft shims
- Dag
10 Mar 2013 07:40 #576313
by Dag
Kz550 tk throttle shaft shims was created by Dag
www.partzilla.com/images/diagrams/kawasaki/08/0122/C-6.png
Hi doing a thorough rebuild of my tk carbs and have one question . In part 6 (please see diagram URL ) are there shims/bushings that hold the throttle shaft (part 25) . Mine appears to have fiber shims but this might be 30 year old an grease/gunk. Anyone know the answer? I don't want to rip them out if they can't be replaced .
- Thank you received: 2098
10 Mar 2013 10:42 #576322
by Patton
Replied by Patton on topic Kz550 tk throttle shaft shims
Would check for further info in these links, courtesy of KZr Member loudhvx.
General
home.comcast.net/~loudgpz/GPZweb/index.html#home
Service manuals
home.comcast.net/~loudgpz/GPZweb/Mnls/Mnls.html
General
Service manuals
- Bunty27
11 Mar 2013 19:11 #576555
by Bunty27
1982 KZ550 LTD
Replied by Bunty27 on topic Kz550 tk throttle shaft shims
The only shim/bushings that I know of are the ones seen in the same diagram (parts 35 & 36) and they look like they are made of rubber. I worked on the same set of TK carbs and are on my KZ550-C3 but that is all I remember seeing during the rebuild. They usually can be popped off _after_ the shaft (part 25) has been removed. I don't remember any bushings kind of thingy on part 6 itself.
1982 KZ550 LTD
