- Thank you received: 5
Which carbs for kz700
- Revboyz
05 Mar 2013 07:20 #575416
by Revboyz
Why leave well enough alone!
Tweak it!
Have 84' kz 700
Had 96' zr6
Had 06' zzr600
Which carbs for kz700 was created by Revboyz
Hi all I have a kz700 I'm looking to get a set of carbs. I currently have a header and would like to install some pods. I hear the bs are hard to tune? Any suggestions? Are the rs series over kill?
Thanks
Kevin
Thanks
Kevin
Tweak it!
Have 84' kz 700
Had 96' zr6
Had 06' zzr600
- baldy110
- Thank you received: 512
05 Mar 2013 13:53 #575458
by baldy110
Replied by baldy110 on topic Which carbs for kz700
Yes, The RS series carbs will be an overkill for a stock engine. The BS34 will work fine on your KZ700, don't let people discourage you on using pod filters with them. With a little patience and knowledge they can be tuned properly. Another option is to find a set of VM24 off a KZ650. They are pretty cheap and they will work as long as you change out the manifolds and they are easy to tune.
- LarryC
05 Mar 2013 15:40 #575469
by LarryC
Not if you buy a jet kit and put a little tuning effort into it.
Larry C.
Replied by LarryC on topic Which carbs for kz700
Revboyz wrote: Hi all I have a kz700 I'm looking to get a set of carbs. I currently have a header and would like to install some pods. I hear the bs are hard to tune? Any suggestions? Are the rs series over kill?
Thanks
Kevin
Larry C.
- Revboyz
05 Mar 2013 16:10 #575471
by Revboyz
Tweak it!
Have 84' kz 700
Had 96' zr6
Had 06' zzr600
Replied by Revboyz on topic Which carbs for kz700
Which r u suggesting?
Tweak it!
Have 84' kz 700
Had 96' zr6
Had 06' zzr600
- gd4now
- Denco where did you go?
- Thank you received: 445
05 Mar 2013 17:33 #575476
by gd4now
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Replied by gd4now on topic Which carbs for kz700
IIRC the kz700 came stock with Mikuni BS34 carbs. Is there something wrong with them on your bike? You do not mention why you want a different set of carbs? What are you looking for, more performance, easier tuning, etc?
Yes tuning for pods is somewhat more difficult with the CV type carbs than it is with the mechanical slide carbs, but as others have said it is not impossible.
1977 KZ650 B1
- Revboyz
05 Mar 2013 17:56 - 05 Mar 2013 17:59 #575479
by Revboyz
Tweak it!
Have 84' kz 700
Had 96' zr6
Had 06' zzr600
Yeah I know the bs34 came stock with the bike. But when I bought it there where not the bs34 stock ones. I'm looking for some more performance. I'm just throwing it out there and seeing what's possibly is a better fit. I may have to do something with my header also it's from a 650 and it's rubbing on my oil cooler line :ohmy:
Tweak it!
Have 84' kz 700
Had 96' zr6
Had 06' zzr600
Last edit: 05 Mar 2013 17:59 by Revboyz. Reason: Added text.
- Thank you received: 797
05 Mar 2013 18:41 #575487
by 531blackbanshee
Replied by 531blackbanshee on topic Which carbs for kz700
kevin,
how many cc's are you running?
- Revboyz
05 Mar 2013 18:47 #575490
by Revboyz
Tweak it!
Have 84' kz 700
Had 96' zr6
Had 06' zzr600
Hi Leon
It a stock kz700 with a exhaust and pods.
Tweak it!
Have 84' kz 700
Had 96' zr6
Had 06' zzr600
