Hard Idle
- freakinbike
03 Mar 2013 16:48 #575080
by freakinbike
1982 GPZ750, stock (for now..)
1973 VW Bus
Can life really get much better?
Hard Idle was created by freakinbike
I have a 1982 KZ750 and it has a very hard time starting. It will start, but it usually needs a jump. I'm going to have the battery tested tomorrow (no shops open on Sunday here in Utah), are there any other electricals I should check out? I had a similar problem on my VW, and a new battery fixed it right away.
The problem after it starts, however, is it has a very rough idle. It needs several minutes to warm up and start to run correctly. Good news though is that when it warms up, it runs like a tank. I've considered a carb rebuild along with new jetting, but maybe they just need to be resynced?
1973 VW Bus
- Davereplicant
03 Mar 2013 17:35 #575090
by Davereplicant
Replied by Davereplicant on topic Hard Idle
Hi, You'll probably find a resynch will help.
To be absolutely sure check everything over - valve clearances, good spark, timing etc...
A strip and clean of the carbs is always an idea and there are plenty examples of peoples methods for doing this on here.
If you can't remember the last time they were cleaned - clean them.
You really only need to think about rejetting after all of the above has been done and you have medded the bike with another pipe, pods or pistons for example.
- pete greek1
- Thank you received: 185
03 Mar 2013 18:11 #575103
by pete greek1
Replied by pete greek1 on topic Hard Idle
start with a new fully charged battery, the bike wont run right, if its not putting out the right amount of volts, if that does'nt fix it do as Dave suggests
- donthaveakawman
- Visitor
03 Mar 2013 20:21 #575130
by donthaveakawman
Replied by donthaveakawman on topic Hard Idle
if that happened to me I would want to choke the thing.
