- Thank you received: 16
Questions on CR carbs for KZ1000ST
- KZ250LTD
03 Mar 2013 03:56 - 03 Mar 2013 04:03 #575032
by KZ250LTD
79 KZ1000ST
Past:
Many.
Questions on CR carbs for KZ1000ST was created by KZ250LTD
I've been thinking about possibly setting up my ST with CR carbs instead of the stockers and had a few questions. Maybe the CR knowledgeable people will be able to help!
First, Dynoman shows that the CR29, CR31, and CR33's will all work for the KZ1000 but I'm not sure of the real world differences between them. For further info, the bike is not a hotrod, if things work out it'll just be running 1045cc's w/stock head, etc. Also, when it says for use with small spigots, what is it referring to?
Second, will these work with a vacuum petcock?
Third, they say that for bikes not running CV carbs, it's necessary to switch out the carb holders. Is there just a size difference or what is the purpose of the switch?
Just wanting to clear up some niggles by refreshing the top end a bit and adding a new set of carbs. Mostly use the bike on long trips anyway so not looking for the absolute best stoplight to stoplight performance.
Tim
Tim
79 KZ1000ST
Past:
Many.
Last edit: 03 Mar 2013 04:03 by KZ250LTD.
- wireman
- Thank you received: 299
03 Mar 2013 04:10 #575033
by wireman
Replied by wireman on topic Questions on CR carbs for KZ1000ST
The 29s should be able to squeeze into the stock carb boots,OMR has written up a lot of stuff on tuning the 29 crs maybe pm him about them.
The following user(s) said Thank You: KZ250LTD
- KZ250LTD
03 Mar 2013 04:24 #575034
by KZ250LTD
79 KZ1000ST
Past:
Many.
Replied by KZ250LTD on topic Questions on CR carbs for KZ1000ST
Thanks, I forgot about the stuff OMR wrote up. Looks like you just have to run the vac petcock on prime, I'll check with him about the rest
79 KZ1000ST
Past:
Many.
- Old Man Rock
- Thank you received: 225
03 Mar 2013 11:03 - 03 Mar 2013 11:06 #575044
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Questions on CR carbs for KZ1000ST
Tim, check your PM....
One thing I forgot to mention as well... long trip elevation changes requires tweaking during the ride.
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 03 Mar 2013 11:06 by Old Man Rock.
- Thank you received: 2098
03 Mar 2013 13:52 #575061
by Patton
If OMR disagrees with regard to CR carbs, I shall gladly defer to his hands-on expertise.
Replied by Patton on topic Questions on CR carbs for KZ1000ST
Any otherwise unused vacuum nipple may be used to supply vacuum to a vacuum operated petcock, by running a vacuum hose from a vacuum nipple to the petcock nipple.KZ250LTD wrote: ... Looks like you just have to run the vac petcock on prime....
