Help finding the problem
- Gorkain
03 Mar 2013 03:24 #575029
by Gorkain
Help finding the problem was created by Gorkain
Alright guys I finally decided to get some personalized help before before the sledgehammer looks any nicer.I got a completely stock,nonrunning KZ750 H LTD -idk the year- that sat for 25 years in mediocre conditions.From the start the carbs (Keihin CV34) have been a pain -take them off,fix problem,put them on,new F#%*ing problem,take back off- ,and replacing the Ignition Coils.
Now after everything it will finally start with very little effort ,but which cylinders fire is a crap shoot.#1 will only fire immediately after cleaning the carbs any other time and the exhaust won't even get warm -plug looks almost white-.#2 and #3 seem to be doing alright albeit #3 runs quite a bit hotter than the others -#2's plug is a nice tan while #3 is slightly darker tan-.#4 usually fires although not as good as #2,#3 -plug is black and sooty so-.
Sorry if this a mess,missing info ,but if anything is needed just ask.I'm just so f#%&ing of these carbs and hurting my novice mechanic brain :lol: .Thanks for any help.
- roy-b-boy-b
- Thank you received: 103
03 Mar 2013 09:59 #575042
by roy-b-boy-b
- Thank you received: 2098
03 Mar 2013 13:28 - 03 Mar 2013 13:32 #575057
by Patton
Replied by Patton on topic Help finding the problem
If not already seen --
Click > www.kzrider.com/filebase/search_result
Click "Search Document"
Type CV in the "Search Keyword" box.
Click the "Search" box.
Last edit: 03 Mar 2013 13:32 by Patton.
03 Mar 2013 13:44 - 03 Mar 2013 13:45 #575060
by Patton
Once carbs are cleaned, should never allow any fuel into the carbs unless the fuel first goes through an aftermarket in-line filter.
Otherwise, the carbs are immediately re-contaminated and again need cleaning.
A popular type of in-line filter:
Attachment filterZ1.jpg not found
Last edit: 03 Mar 2013 13:45 by Patton.
