- Thank you received: 16
How to tell 34mm CVs for KZ and GS Suzukis apart ?
- mtkawboy
02 Mar 2013 16:51 #574913
by mtkawboy
How to tell 34mm CVs for KZ and GS Suzukis apart ? was created by mtkawboy
Someeone gave me a nice set of 34 mm CV Mikunis. Does anyone know how to tell by the outside which they fit, KZ1000J/KZ1100 or Suzuki GS1100E ? Took bowl off of one and it appears to have a jet kit in it. Main is new 132.5 and pilot is new 32.5 best I can tell. I didnt check the needle yet. Thanks for any help
- etbike3135
- Thank you received: 50
02 Mar 2013 17:14 #574916
by etbike3135
1973 Kawasaki Z1
18 years in dragbikes
Replied by etbike3135 on topic How to tell 34mm CVs for KZ and GS Suzukis apart ?
One of the biggest tells is a choke lever. Most Suzuki's had a cable operated choke and the Kawis had a pull lever right on the side of the carbs.
1973 Kawasaki Z1
- gd4now
- Denco where did you go?
- Thank you received: 445
02 Mar 2013 19:05 #574926
by gd4now
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Replied by gd4now on topic How to tell 34mm CVs for KZ and GS Suzukis apart ?
There should be an ID stamped on the carbs (on one of the flanges where the carbs connect to the carb assembly holder. It is my understanding that the carbs used on the Suzuki's begin with a 4.
1977 KZ650 B1
- donthaveakawman
- Visitor
02 Mar 2013 19:50 #574938
by donthaveakawman
Replied by donthaveakawman on topic How to tell 34mm CVs for KZ and GS Suzukis apart ?
picture?
- mtkawboy
03 Mar 2013 17:04 #575083
by mtkawboy
Replied by mtkawboy on topic How to tell 34mm CVs for KZ and GS Suzukis apart ?
Carbs have a choke knob so I guess they are Kawasakis. No pictures, dont know how to post them. If you need them I can post them on my email
- donthaveakawman
- Visitor
03 Mar 2013 17:41 #575092
by donthaveakawman
I don't need them.
- Thank you received: 2098
03 Mar 2013 18:24 - 03 Mar 2013 18:27 #575108
by Patton
Replied by Patton on topic How to tell 34mm CVs for KZ and GS Suzukis apart ?
mtkawboy wrote: ...No pictures, dont know how to post them....
Attachment picpostnewsite912x671.jpg not found
Last edit: 03 Mar 2013 18:27 by Patton.
- mtkawboy
04 Mar 2013 19:31 - 04 Mar 2013 19:35 #575316
by mtkawboy
Still working on picture. Cant find any numbers or letters but to the right of the choke lever looking at the carbs from the end is a cover about 1 inch across with 3 screws in it. What does that do and does that narrow anything down ? I have 3 sets of GS1100 Cvs and have never seen that cover on any of them
Last edit: 04 Mar 2013 19:35 by mtkawboy.
- mtkawboy
05 Mar 2013 20:01 - 05 Mar 2013 20:09 #575500
by mtkawboy
Mystery cover by choke lever is a coasting diaphragm Id guess like an anti back fire valve ?? Its found on carbs for an 81 & 82 KZ1000J and on the ELR replica. Nothing else I looked up like the police 1000s show this part. If anyone has any more info Id sure appreciate hearing about it.
Last edit: 05 Mar 2013 20:09 by mtkawboy.
- woodman
10 Mar 2013 20:10 - 10 Mar 2013 20:11 #576409
by woodman
Replied by woodman on topic How to tell 34mm CVs for KZ and GS Suzukis apart ?
Attachment CV.png not found
Last edit: 10 Mar 2013 20:11 by woodman. Reason: cancel
- mtkawboy
10 Mar 2013 20:44 #576419
by mtkawboy
The picture above is the carbs Im talking about. The book only shows them with these diaphragms on each carb {the cover with 3 screws} for KZ1000Js and ELR 1000s, is that correct ? There are no numbers anywhere on the carbs where they normally are. Thanks for your help
