hi, I have been looking to use a cold air intake on this bike, maybe something of a ram air.
what I am looking to do is a custom one time deal and I want to use the stock rubber air horns and cut out the airbox where they go into.
from there I want to use a plastic weld/epoxy to set it into a big tube and run it out the side with a cone air filter and a scoop type intake to get the most cold air I can.
where should I route this to keep it away from heat while being subtle and appearing factory?
maybe under the frame and over the engine with heat wrap.
just an idea at this time.
