- Thank you received: 2
Installing BS34 Carbs on a 1979 KZ650
- Arttodd
01 Mar 2013 23:38 #574817
by Arttodd
Arttodd
1979 Kawasaki KZ650 B3
Rock, Stock Old School Kaw
Installing BS34 Carbs on a 1979 KZ650 was created by Arttodd
I plan on installing a set of BS34's on a 1979 KZ650 this spring. Are there any good tips that would make the install easy?
Arttodd
- donthaveakawman
- Visitor
01 Mar 2013 23:45 #574819
by donthaveakawman
Replied by donthaveakawman on topic Installing BS34 Carbs on a 1979 KZ650
not sure how big your carb holders are, take some from a 1980 750 and they should fit, are those cvc or slidebore carbs?
- Thank you received: 2098
01 Mar 2013 23:58 - 01 Mar 2013 23:59 #574822
by Patton
Installation guidelines from www.wgcarbs.com
Click > www.wgcarbs.com//index.php?option=com_co...sk=view&id=Itemid=87
Am wondering if BS34 may be too much carb for KZ650.
Fitment issues aside, any particular reason for abandoning the stock manual slide carbs?
And with regard to tuning, pods are even more problematic on CV carbs.
Replied by Patton on topic Installing BS34 Carbs on a 1979 KZ650
Arttodd wrote: I plan on installing a set of BS34's on a 1979 KZ650 this spring. Are there any good tips that would make the install easy?
Last edit: 01 Mar 2013 23:59 by Patton.
- Arttodd
02 Mar 2013 00:11 #574826
by Arttodd
Arttodd
Replied by Arttodd on topic Installing BS34 Carbs on a 1979 KZ650
I've heard that the BS34 CV carbs improve performance and throttle response. I intend to have the head rebuilt and ported, new cams, and maybe a 700 cc kit. The BS34's are to compliment the modifications.
Arttodd
- RTGPZ
- Thank you received: 7
02 Mar 2013 00:18 #574829
by RTGPZ
old school w/ new look
02gsxr 1000 front forks w/6 piston calipers
06 gxsr 750 rear suspension
6 speed trans out of gpz550
Reinforced frame
Replied by RTGPZ on topic Installing BS34 Carbs on a 1979 KZ650
I don't think you ll have any problems putting them on, I personally dont like bs34. mine work ok but to temperamental. But I ve got pods and might be why I ve got a slight hickup at low rpm. Back to your question good luck if you use them. One throttle cable is nice.
Reinforced frame
- donthaveakawman
- Visitor
02 Mar 2013 00:24 #574830
by donthaveakawman
bad monkey, pods on cvc's don't work well. maybe if you can link them together somehow.
