- Thank you received: 2
more noobie help
- natetru
28 Feb 2013 19:31 #574614
by natetru
1982 kz1000 m2 csr
more noobie help was created by natetru
1982 kz 1000, at idle i have a random miss....seems to be same cylinder everytime. I can feel/see a poof when the miss happens inbetween the block and the back side of carb....is that an indicator of bad carb boot? Thanks in advance
1982 kz1000 m2 csr
- wireman
- Thank you received: 299
28 Feb 2013 19:34 #574616
by wireman
Replied by wireman on topic more noobie help
Yes,spray some carb cleaner around that boot while motor is running and see if idle changes
- Thank you received: 2829
28 Feb 2013 19:39 #574618
by 650ed
Agreed. Be sure to temporarily set the idle as low as possible when doing the test. This will yield the most obvious effect if the carb holder is leaking, because it applies more vacuum to the carb holders when the carb slides are closed as much as possible. Ed
Replied by 650ed on topic more noobie help
wireman wrote: Yes,spray some carb cleaner around that boot while motor is running and see if idle changes
- natetru
