1908 KZ 1000 LTD JETTING
- need to know
24 Feb 2013 01:22 - 25 Feb 2013 17:44 #573812
by need to know
1908 KZ 1000 LTD JETTING was created by need to know
Hello, Help from anyone with experience jetting Z1s & KZs would be appreciated.
I need to jet the carbs.
I have a 1980 KZ 1000 B 4 LTD.
It has a Kerker 4 into 1 { Baffle Removed }. I like the sound....
It has the individual K&N air filters - the larger ones not the cones.
I believe the carbs to be the original stock ones ?? with the idle air adjustment screw on the side of each carb.
I believe the stock jetting was.
15 pilot jet.
102 main jet.
I'm not sure what position the needle was supposed to be set at?
Since I'm sure someone has changed the jets and or settings I am hoping to find someone who has the same set up and can tell me what jetting you have, so I have some sort of starting point. I would like to minimize the # of times I have to tear down to re-jet.
The jets that are in it now are.
15 pilot jet.
120 main jet.
Thanks !
15 pilot jet.
102 main jet.
15 pilot jet.
120 main jet.
Thanks !
Last edit: 25 Feb 2013 17:44 by need to know.
- gd4now
- Denco where did you go?
- Thank you received: 445
24 Feb 2013 02:00 #573822
by gd4now
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Replied by gd4now on topic 1908 KZ 1000 LTD JETTING
How does it run with those jets? What do the plugs look like? Will idle well, will it pull to red line well?
IIRC the stock carbs on an 80LTD were vm26ss carbs and in the US market they had an accelerator pump, is that what you are working with? I think stock the needle was set to the 4th slot. Do the carbs have a pilot or air screw?
Off the top of my head I would think you would need to start with a larger pilot jet, a 17.5 and a smaller main, more like a 115 or so.
1977 KZ650 B1
The following user(s) said Thank You: need to know
- Mcdroid
- Gone Kwackers
- Thank you received: 319
24 Feb 2013 08:53 #573849
by Mcdroid
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Replied by Mcdroid on topic 1908 KZ 1000 LTD JETTING
1980 LTD model had VM28SS carbs. Stock jetting was 102.5 main and 15 pilot. Clip was on the third (from bottow) slot.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- roy-b-boy-b
- Thank you received: 103
24 Feb 2013 11:37 #573866
by roy-b-boy-b
Replied by roy-b-boy-b on topic 1908 KZ 1000 LTD JETTING
I would get a size 20 idle jet. How does the bike run?
- etbike3135
- Thank you received: 50
24 Feb 2013 12:17 #573877
by etbike3135
1973 Kawasaki Z1
18 years in dragbikes
Replied by etbike3135 on topic 1908 KZ 1000 LTD JETTING
17.5 pilots and you have the right main jet.
1973 Kawasaki Z1
- need to know
25 Feb 2013 18:46 #574095
by need to know
Replied by need to know on topic 1908 KZ 1000 LTD JETTING
Thanks, It seems to run pretty good mid range to full throttle, but I've only driven it in very short amounts of time . At Idle it intermittently sneezes out the carbs and pops at the exhaust, but NOT MUCH. However it does NOT want to run very well at low end and at idle it runs hot very fast.
I'm sure the pilot jet is too small. I have not checked the spark plugs as far as the mid and top end yet.There are no air leaks around the carbs. The carbs have a pilot screw on the side of each carb. They do not have the air screw that was under some of the carbs. They do have an accelerator pump. Is there a good place that sells good jets with a big selection for a good price? I hope to try something soon as spring is coming!
