carbs peeing
  • richie1
  • richie1's Avatar Topic Author
carbs peeing
26 Jun 2006 18:12
#57359
i just got a 78 kz400 and it won't fire,ben stored fr 19 yrs anyway ot will run on carb cleaner but when i hook up the gad tank to it it just pours it out the vent tube and overflow on the one carb nothin fro, the other and nothin happens any idea?
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
Re: carbs peeing
26 Jun 2006 18:49
#57371
Does the '78 have a vacuum-based petcock (instead of gravity)? If so, you may be accidentally leaving it on "prime" or something...
Either way, it sounds like the float (in the bowl) isn't working, most likely due to years of sitting in gummed up gas!! Looks like they need to come off and get cleaned....
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • richie1
Re: carbs peeing
26 Jun 2006 18:51
#57373
theres 2 hoses off the petcock one thats wet and ones always dry the dry one is smaller then the larger one...if that helps?
  • wireman
  • wireman's Avatar
Re: carbs peeing
26 Jun 2006 18:58
#57375
floats sticking,dont tell wired george i said this but try banging on bottem of carbs with a screwdriver or hammer handle.:whistle:
  • richie1
Re: carbs peeing
26 Jun 2006 19:06
#57379
ive already got them off and ordered a rebuilt kit assuming that they needed it so from ur responses i think i go ahaead and rebuild, and hope it works
thanks any more tips or tricks are cool
  • steell
  • steell's Avatar
Re: carbs peeing
26 Jun 2006 19:58
#57407
You have a spycam in my garage?:laugh: :laugh:
  • wireman
  • wireman's Avatar
Re: carbs peeing
26 Jun 2006 20:11
#57412
great now WiredGeorge is gonna have us both going to carb sensitivity training!:S :woohoo: :silly: :P
  • ran429
  • ran429's Avatar
  • Master of FREE rides!
Re: carbs peeing
26 Jun 2006 23:30
#57431
You're supposed to use the handle end?
And I thought the hammered metal look was highly saught after, like a copper pot or fishing lure or something like that?:whistle:
  • wiredgeorge
  • wiredgeorge's Avatar
Re: carbs peeing
27 Jun 2006 06:48
#57464
Tapping the bowl with something isn't as dumb an idea as it sounds... if the float hangs up within the bowl and then drops when you tap it, it tells you that you need to remove the bowl and see why it is hanging up. Generally a float is bent and hanging on the top of the bowl or on the edge of a gasket. BTW: They aren't my carbs so you can go over and help bang on the bowls for all I care bwhahaha
  • RomSpaceKnight
  • RomSpaceKnight's Avatar
Re: carbs peeing
28 Jun 2006 10:51
#57767
The wet one is the fuel line the other is a vacuum line from the carbs a nipple on one of the intake boots is the source of vacuum. Sounds like evaporated gas has plugged up float needle valves and causing hangup. Petcock in PRIME position will allow fuel to flow without engine running but the float valve should stop overflow if working properly. A rebuild or darn good cleaning should rectify problem.
  • wireman
  • wireman's Avatar
Re: carbs peeing
28 Jun 2006 17:34
#57879
hey rom,how ya feeling?welcome back to the nuthouse!:P
