Leaky intake manifolds?
- Freekz1000
21 Feb 2013 19:56 #573486
by Freekz1000
Leaky intake manifolds? was created by Freekz1000
I bought a set of carb sync gauges off of Amazon and hooked them up to the manifolds to sync my carbs. it settles in the section where is reads that there is a valve timing issue or a leaky intake manifold. the bike is a 1978 kz1000. My question is are the gauges usually accurate and would you recommend to repair or replace the manifolds. is there another way to test for leaks?
- MFolks
- Thank you received: 540
21 Feb 2013 20:37 #573501
by MFolks
Replied by MFolks on topic Leaky intake manifolds?
There are two ways,the first envolves spraying a light oil/cleaner like WD-40,or carb & brake cleaner on an operating engine.
The second way:
(Using An UNLIT Propane Torch For Vacuum Leaks)
The second way:
- MFolks
21 Feb 2013 20:40 #573504
by MFolks
New carb holders(manifolds),along with new rubber plugs for the sync ports would be the way I'd go, as trying to repair the cracks will be time consuming. Check the rubber boots(tubing from the air filter box) if you have one, for cracks too.
- Freekz1000
22 Feb 2013 19:14 #573608
by Freekz1000
Replied by Freekz1000 on topic Leaky intake manifolds?
I have some bad manifolds, thanks for the help.
- Thank you received: 2098
22 Feb 2013 19:25 #573610
by Patton
Replied by Patton on topic Leaky intake manifolds?
