Position of vacuum piston holes KZ400
- 51-9
15 Feb 2013 04:56 #572456
by 51-9
Position of vacuum piston holes KZ400 was created by 51-9
Hi KZriders need your HELP!! :ohmy:
I had to change the libranes of my KEIHIN D 757 carbs (KZ 400 D, 1977) due to several holes in there.
Now I want to install the new libranes on the vacuum piston.
BUT: I DID NOT MARK the position of the vacuum piston/libranes. Now I have no idea in which position the two tiny holes next to the jet needle have to be in the carb. Do they have to face towards the air filter? Has anybody of you a picture of this carb type with the top cap off? Since now I know WHY there is a kind of marking in the libranes - but I already cut them off..
Hopefully someone´s able to help me.
As I´m new here I try to upload pics of my KZ400 Cafe later on these days.
Regards from Austria!
- Motor Head
- Thank you received: 391
15 Feb 2013 09:57 #572465
by Motor Head
Replied by Motor Head on topic Position of vacuum piston holes KZ400
Engine side, towards the motor. Those little holes need to see engine vacuum, which will increase as the throttle blades are opened.
Hope this helps.
Hope this helps.
The following user(s) said Thank You: 51-9
- Thank you received: 2098
15 Feb 2013 09:58 #572466
by Patton
Replied by Patton on topic Position of vacuum piston holes KZ400
Maybe this link will provide some helpful info:
Click here > www.armbell.com/forum/viewtopic.php?p=99...9797b00&mforum=kz400
- 51-9
17 Feb 2013 09:49 - 17 Feb 2013 09:57 #572841
by 51-9
Replied by 51-9 on topic Position of vacuum piston holes KZ400
Hi guys, thanks a lot for your help!
If I got you right, the position of the holes is like in the pic (not fixed yet..)?
ok.... have to find out how to upload pics here...
Last edit: 17 Feb 2013 09:57 by 51-9.
- 51-9
17 Feb 2013 11:12 - 17 Feb 2013 11:21 #572854
by 51-9
Last edit: 17 Feb 2013 11:21 by 51-9.
- Motor Head
17 Feb 2013 11:33 #572857
by Motor Head
Yes that is correct.
Patton has a great tutorial for posting pictures on the site. Look here: www.kzrider.com/forum/8-about-the-site/1...ost-pics-resize-pics
- 51-9
17 Feb 2013 11:55 #572860
by 51-9
Many thanks to Motor Head!
..and thx for the helpfull link - it´s obvious that I needed it...
17 Feb 2013 12:00 #572862
by Patton
To post an image appearing within the forum message:
This pic went into the "KZ GALLERY" which is a different location from showing within the FORUM thread.51-9 wrote: www.kzrider.com/gallery/gallery-member-f...in-carb-piston1-6860 [/img]
Attachment picpostnewsite912x671.jpg not found
