- Thank you received: 2
KZ750 Carb Help! Whats the screw on the top front
- ironslave
- sup
12 Feb 2013 00:18 #572019
by ironslave
1981 KZ750 LTD
KZ750 Carb Help! Whats the screw on the top front was created by ironslave
So looking at the carbs from behind on top in the front of each carb is a screw and I believe it is the air mix screw but I am not really sure. How to I use these to get the best performance across all carbs?
1981 KZ750 LTD
- gd4now
- Denco where did you go?
- Thank you received: 445
12 Feb 2013 02:52 #572036
by gd4now
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Replied by gd4now on topic KZ750 Carb Help! Whats the screw on the top front
The stock carbs on a 81 750 LTD were Keihin CV34's. The screw you are speaking of is a pilot screw and not an air screw.
It either decreases or increases the amount of the air/fuel mix from the pilot circuit into the carb on the engine side of the butterfly valve. It does not effect the ratio of the fuel/air mix in the pilot circuit. Rather, just how much is allowed to enter via the pilot outlet.
An air screw would either decrease or increase the amount of air from the pilot air jet allowed to mix with the fuel pulled up via the pilot jet - it effects the ratio of air/fuel mix in the pilot circuit.
Adjustment is just the opposite for each.
Pilot screw - turn out to increase and turn in to decrease the amount of air/fuel mix allowed to enter via the pilot outlet
Air screw - turn out to lean the air/fuel mix in the pilot circuit or turn in to richen the mix in the pilot circuit
1977 KZ650 B1
The following user(s) said Thank You: ironslave
- donthaveakawman
- Visitor
12 Feb 2013 02:55 #572038
by donthaveakawman
Replied by donthaveakawman on topic KZ750 Carb Help! Whats the screw on the top front
yup!
- ironslave
- sup
12 Feb 2013 03:31 #572046
by ironslave
Ok to make sure I have it right... Turn out to increase pilot fuel amount which is premixed. Turn in to decrease premixed pilot feed. I know why I am having issues with it then. lol so how do I find the optimum setting of each?
1981 KZ750 LTD
Replied by ironslave on topic KZ750 Carb Help! Whats the screw on the top front
gd4now wrote: Pilot screw - turn out to increase and turn in to decrease the amount of air/fuel mix allowed to enter via the pilot outlet
1981 KZ750 LTD
- Old Man Rock
- Thank you received: 225
12 Feb 2013 07:59 - 12 Feb 2013 08:04 #572055
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic KZ750 Carb Help! Whats the screw on the top front
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 12 Feb 2013 08:04 by Old Man Rock.
- donthaveakawman
- Visitor
12 Feb 2013 10:39 #572063
by donthaveakawman
I have experience in the matter of cvc axles, the manual says to set them at 2 full turns out from the bottom and you can mettle with them then.
