Petcock and choke 81 kz440??
- bucky242
09 Feb 2013 16:38 #571631
by bucky242
Blue 1980 kz440 b1 with clubmans 2 to 2 exhaust rejetted carb.
Petcock and choke 81 kz440?? was created by bucky242
How should I leave the Petcock and choke set on my kz440 over a longer period of time?
Choke up down? Petcock to on?
- donthaveakawman
- Visitor
10 Feb 2013 07:48 #571714
by donthaveakawman
Replied by donthaveakawman on topic Petcock and choke 81 kz440??
what does it say, on and off?
- bucky242
11 Feb 2013 13:48 #571942
by bucky242
Replied by bucky242 on topic Petcock and choke 81 kz440??
Petcock has on reserve and prime
- Thank you received: 2098
11 Feb 2013 14:38 #571950
by Patton
For storage, would at least drain the carb bowls.
Good to leave vacuum operated petcock in ON or RES position (which supposedly disallows fuel flow when the engine isn't running); but better to disconnect the fuel hose and vacuum hose from the petcock, to assure no fuel enters carbs. Best to disconnect fuel hoses at the carbs, which prevents any fuel remaining in the line from draining into the carbs.
And at least fill the fuel tank completely full with fresh gasoline, and add a preservative product such as "Stabil" to slow deterioration of the gasoline. But better to drain all gasoline from the tank, and store with the tank dry. And best to protect interior of the stored dry fuel tank with application of a product such as the oil based fog spray mist as used in marine applications.
Leave the choke OFF.
Cover the bike with a breathable cover during storage.
Other things to be done for storage would include:
Using a center stand or other method to keep the tires off the floor;
Changing the oil and filter before storing;
Oil moving carb parts and moveable chassis components.
Also a good idea to remove the battery; and leave it on the bench, with trickle charger (battery tender) attached.
And flush brake systems with fresh brake fluid.
Replied by Patton on topic Petcock and choke 81 kz440??
bucky242 wrote: How should I leave the Petcock and choke set on my kz440 over a longer period of time?
- donthaveakawman
- Visitor
12 Feb 2013 21:17 #572154
by donthaveakawman
don't take it over 2k rpm with the choke on.
