- Thank you received: 18
Fuel line routing?
- mvent
08 Feb 2013 20:21 #571548
by mvent
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
Fuel line routing? was created by mvent
Replace my leaky vacuum petcock with a Pingel today,ran the fuel line straight out of barb with an inline filter,down between carbs 3-4, then back up to a T,between 2-3,my question is,will I have a flow problem at speed routing fuel line this way?
TIA
Mike
TIA
Mike
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
- Thank you received: 2098
08 Feb 2013 23:37 #571571
by Patton
Replied by Patton on topic Fuel line routing?
Single fuel hose down from petcock that tee's out and up to the two carb fuel inlets should be just fine.
Main objective is no kink in the fuel hose.
- mvent
09 Feb 2013 12:09 #571613
by mvent
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
Replied by mvent on topic Fuel line routing?
Thanks,no kinks just a loop around carbs.
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
