81 750 ltd carb hoses
- maddartist
25 Jun 2006 20:00
Hi Again
My 1981 750-4 ltd is still pissin fuel out the carbs.
Does anyone have a diagram on the vent/fuel hoses?
I tried lookin thru 37 pages here and no go.
I think some lines are capped that shouldnt be.
I'm pretty sure their kehin? carbs.Wired george was gonna look for a diagram for me months ago but everyone here keeps him busy:cheer:
thank ya
Post edited by: maddartist, at: 2006/06/25 23:01
thank ya
- wiredgeorge
Re: 81 750 ltd carb hoses
26 Jun 2006 04:39
I have a BS series carb connection link on my web site. I can't recall if you carbs are Keihin or Mikuni. The hook up for the Keihins is similar to the BS34. Have a look at the connection page and if you have questions, I have a carb forum on my web site as well... stop in and ask your question. Cheers
- maddartist
26 Jun 2006 06:34
Hey G
They are Keihin carbs, I'll check your site out hopefully i can get my ride goin by this weekend.
thanks alot bud
thanks alot bud
- JR
26 Jun 2006 07:42
If this works then below you will se a pic from the Kawasaki website. Keihins are pretty simple. There are overflow nipples on the bottom of the carb/float bowl to which you should connect tubes and vacuum nipples where I drew the lines. These vacuum nipples should be capped. If you have vacuum activated petcock then you will have a line go from one of the nipples - usually #2 - to the petcock. There are no vent holes or nipples as on other carbs. Look for a very recent - within the past few days - post by ran429 who had similar isues with fuel pouring out.
Good luck
Good luck
- wiredgeorge
26 Jun 2006 12:46
JR, the reason I pointed him to the BS carb connect page on my web site is because of the similarity to the version of the BS with no vent tees between the 1&2 and 3&4 carbs. If you or anyone has a good pic of the Keihins, I would be glad to post it with connections on my site as this comes up regularly. I don't have a good picture right now and my next CV34 set won't be done for a couple weeks. If no one has a good pic, I will wait till that set is complete and snap some pics.
Thanks
Thanks
- JR
26 Jun 2006 18:13
I might have something on my home computer but it will be thursday night or friday morning before I get back and get a chance to look.
- wiredgeorge
27 Jun 2006 06:52
I don't keep many Keihin CV carbs in the shop... only for parts so they are not complete or all assembled as I recall and pretty dirty looking. If you have a pic, that would be great!
- jason8887
27 Jun 2006 08:28
If you are constantly leaking fuel from the overflow nipples on the bottom of the bowls, you may check the brass tubes that stick up from the inside of the bowls for cracks. I have fixed many a leaky carb by soldering a crack in one of these tubes. Good luck!
