Seeking carb model and size advice
- daveo
30 Jan 2013 20:26 - 31 Jan 2013 12:10
I've been considering making a carb upgrade, and need some help determining the best choice, correct model and size (flat slide, or round slide) Mikuni Smoothbores, for my bike. She's great now, but I want to make her better!
The bike: 1982 1100A...stock except V&H header, dyna 2000 w/mini-coils, electrex rotor, APE chain adj./ cyl studs and nuts, pod filters. Top end freshened over the past few years.
![:P :P](/media/kunena/emoticons/15.png)
1982 KZ1100-A2
Last edit: 31 Jan 2013 12:10 by daveo.
- baldy110
Re: Seeking carb model and size advice
31 Jan 2013 13:46 - 31 Jan 2013 13:46
For a stock bike I wouldn't change the carbs. By the way your bike is beautiful.
Last edit: 31 Jan 2013 13:46 by baldy110.
The following user(s) said Thank You: wireman, daveo
- daveo
31 Jan 2013 17:14
Likely little gain, and a lot invested for it? Them carbs are kinda pricey.
Would you suggest installing a Dynojet kit? I have an extra set of vacuum slides from a police bike, which could be modified per the kit instructions. Each police slide cylinder has a restriction hole (in the side) to plug.
1982 KZ1100-A2
- daveo
Last edit: 03 Feb 2013 20:07 by daveo. Reason: updated
- turboking
03 Feb 2013 14:31
leave it alone. :blink: too nice to mess with. :laugh: your bike is probably worth more the way it is
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
- kzzoid
03 Feb 2013 14:49
mikuni vm 33 smoothbores or rs36 would do the job, they also have the advantage of a 1/4 turn throttle response bringing the power on with less effort, your present k&n filter setup will fit right on both those carbs as well, cheers
kz1000,zx11,kx500
- daveo
03 Feb 2013 15:12 - 03 Feb 2013 15:14
@Turboking: Thanks man, but heard that already...dang-it! Just want to tink-her some more. I know she likes it, cause every touch makes her moan better.
I've been bringing her back from Vetter-ville since September, 2000.
1982 KZ1100-A2
Last edit: 03 Feb 2013 15:14 by daveo. Reason: add
- wireman
03 Feb 2013 15:37
29-31 cr specials,Ive run much bigger motors on good ol 29 smoothbores in the past.
but crs are much easier/cheaper to get
![B) B)](/media/kunena/emoticons/1.png)
03 Feb 2013 15:46She's great now, but I want to make her better!... pod filters....daveo wrote: I've been considering making a carb upgrade, and need some help determining the best choice, correct model and size (flat slide, or round slide) Mikuni Smoothbores, for my bike. She's great now, but I want to make her better!
IMO, a significant upgrade would be returning to the stock airbox.
![:) :)](/media/kunena/emoticons/8.png)
The following user(s) said Thank You: peter1958, daveo
- daveo
03 Feb 2013 16:13
Patton,
You may be right, but then I lose the storage area where the air-box was. I converted that space into a much-needed place to put stuff. But it is easily converted back.
1982 KZ1100-A2
03 Feb 2013 16:27
From a forum search, here are 74 links with information about tuning efforts on CV carbs with pods.
Click > www.kzrider.com/forum/advsearch?q=kit+cv...te=all&childforums=1
- Old Man Rock
03 Feb 2013 19:53
Are you planning on head work (enlarged valves/P&P/.375 (+) lift camshafts etc...) otherwise, gain may be somewhat disappointing for you...
Now through in the mentioned items, oh yeah that will wake her up with some 29 -31 Keihins......
![;) ;)](/media/kunena/emoticons/11.png)
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
