- Thank you received: 664
Seeking carb model and size advice
- daveo
The bike: 1982 1100A...stock except V&H header, dyna 2000 w/mini-coils, electrex rotor, APE chain adj./ cyl studs and nuts, pod filters. Top end freshened over the past few years.
1982 KZ1100-A2
- baldy110
- Thank you received: 512
- daveo
Would you suggest installing a Dynojet kit? I have an extra set of vacuum slides from a police bike, which could be modified per the kit instructions. Each police slide cylinder has a restriction hole (in the side) to plug.
1982 KZ1100-A2
- daveo
- turboking
- Thank you received: 106
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
- kzzoid
kz1000,zx11,kx500
- daveo
I've been bringing her back from Vetter-ville since September, 2000.
1982 KZ1100-A2
- wireman
- Thank you received: 299
but crs are much easier/cheaper to get
- Thank you received: 2098
She's great now, but I want to make her better!... pod filters....daveo wrote: I've been considering making a carb upgrade, and need some help determining the best choice, correct model and size (flat slide, or round slide) Mikuni Smoothbores, for my bike. She's great now, but I want to make her better!
IMO, a significant upgrade would be returning to the stock airbox.
- daveo
You may be right, but then I lose the storage area where the air-box was. I converted that space into a much-needed place to put stuff. But it is easily converted back.
1982 KZ1100-A2
Click > www.kzrider.com/forum/advsearch?q=kit+cv...te=all&childforums=1
- Old Man Rock
- Thank you received: 225
Now through in the mentioned items, oh yeah that will wake her up with some 29 -31 Keihins......
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
