Carb ID help, please
  • buddyro
  • buddyro's Avatar Topic Author
25 Jun 2006 10:15
#56990
Hey all, my bike is a 77 kz1000. Not sure what my carbs are, but they are not from the same bike. Can any one help, or suggest a way for me to research this.
Post edited by: buddyro, at: 2006/06/25 13:18
  • 77KZ650
  • 77KZ650's Avatar
Re: Carb ID help, please
25 Jun 2006 10:18
#56992
have any pics?
07 MDP Rookie of the Year
  • buddyro
25 Jun 2006 10:20
#56994
need more?
  • Z1Bama
  • Z1Bama's Avatar
25 Jun 2006 10:21
#56995
Z1 Enterprises have a carb idenify photo site to compare your pics
  • buddyro
25 Jun 2006 10:24
#56998
Really!! Haven't seen that yet. Thanks!
  • wireman
  • wireman's Avatar
25 Jun 2006 11:23
#57017
26s would be my guess ,unless they are an old set of 29s with 26 bowls.;)
  • Z1Bama
  • Z1Bama's Avatar
25 Jun 2006 12:21
#57029
wireman I think your right, 26ers would be my guess because of the fuel tees between 1/2 and 3/4, with what looks like two vents on the top, and overflows on the bottom cups, my old 29 smoothes had one fuel tee center of 2/3. Least I think it did.
  • wiredgeorge
  • wiredgeorge's Avatar
25 Jun 2006 17:43
#57089
76 VM26... They are missing the bracket that connects the four tops. It served no purpose and tends to rust so most folks would have a tendency to pitch it. The air screws are the give-away. The 77/78 VM26 had pilot fuel mix screws on the bottom towards the front (engine side) of the bowl. There is a faint and hard to read ID mark on the flange of the outside carbs: Z12 00 with the Z12 on top and the 00 on the bottom. I will attach a pic of what these carbs look like with the top bracket installed.
Post edited by: wiredgeorge, at: 2006/06/25 20:45
  • Z1Bama
  • Z1Bama's Avatar
25 Jun 2006 18:04
#57098
I wondered about that top bracket, I left it off a set of 26's and kept it where I could fine it, but I my self couldn't see a use for it other than maybe to help hold things together better under vibration. It just seemed like a useless step forgotten anyway. Glad to hear your input on that wg.
  • wiredgeorge
25 Jun 2006 18:12
#57101
If my memory serves, the early 77 KZ1000 carbs also had the bracket or perhaps it was the 77 KZ900A5... anyway, I can't see where it did anything. None of the others had the bracket or seem to need it. Those 76 carbs are virtually identical in a lot of ways to the zillions of GS750/850/1000 VM26 carbs sold as well as the VM26s on the KZ1000s from 77-78. None of these used the bracket. The bracket looks OK if polished (well, fine wire brush wheel) and then sprayed with acrylic laquer which is what I do on the sets I rebuild. The clear laquer is necessary so that the darn thing doesn't rust up again quickly.
  • Z1Bama
  • Z1Bama's Avatar
26 Jun 2006 02:45
#57180
What I thought I would do after you refreshed my memory on the bracket, was to take it along with the other parts I was gathering to take for chrome plating. Might as well keep the 26 carb set together.
