carbs for GPZ Eleven?
- jarrad
29 Jan 2013 18:29
hey guys i have a few sets of carbs here for project new oldskool
a set of 34mm cv's and a set of 28mm smoothbores.
im guessing the 34's would be better for my build or should i sell both
and try to fing the cash for some flatslides?
"IF EVERYONE HAS ONE, I DONT WANT ONE"
79 z1000st BUILD:
www.streetfighters.com.au/for...-OLDSKOOL-quot
R6 build:
www.customfighters.com/forums...ad.php?t=53108
KDX build:
www.dirtrider.net/forums3/sho...d.php?t=166143
79 z1000st BUILD:
R6 build:
KDX build:
- baldy110
Re: carbs for GPZ Eleven?
29 Jan 2013 18:47 - 29 Jan 2013 18:48
First off those VM28's you have are not smoothbores and as for the BS34 I installed a set on my ELR clone without much success. My engine is an 82 GPZ1100 with an MTC 1135cc big bore kit with stage 1 head porting from PitStop Performance. Could never get them tuned correctly, really bad flat spot right off idle and could not get them to idle down as they should. I put a lot of money and time into those BS34's with no good results.
There are people who have used BS34 with success on the 1100 engine but based on my own experiences I would stay away from them.
Those VM28's are going to be to small for that engine.
I eventually ended up with Mikuni RS36 flatslides and they work fantastic.
Do yourself a favor and just sell what you have and buy the Mikuni RS flatslides.
Last edit: 29 Jan 2013 18:48 by baldy110.
- jarrad
29 Jan 2013 19:33
Hmmm i thought that might be the case....
after a bit of research i have found there are 28's and 29's
i know that even 29's would be too small, im just trying to identify them
so i can sell them.
i think they may be 29's
so i can sell them.
79 z1000st BUILD:
R6 build:
KDX build:
79 z1000st BUILD:
R6 build:
KDX build:
- Roadflyer
29 Jan 2013 20:10The stock 28's on my 79 kz1000st actually measure about 28.5 just like yours do.
1979 kz1000 shaftie rebuild project
1045 wiseco 10.25-1 pistons
Kenny Harmon 380 lift cams
- wireman
29 Jan 2013 23:39
Post a right side picture of the carbs as they would sit on bike,the bodies on the 29s are aluminum not the heavy die cast/zinc like 26s/28s
- moorepower
30 Jan 2013 17:37
If you can afford it, I'd definitely go for some flatslides.
I had some Mikuni RS36's on my '81 GPZ1100 many years ago. The only problem was that the fuel tank petcock rubbed the top of the #1 carb, so I had to replace the petcock with an inline type. Other than that, I loved the carbs. Wish I still had them.
'81 GPZ1100 mutt, coming out of 10 year hibernation
- gd4now
- Denco where did you go?
30 Jan 2013 20:14 - 30 Jan 2013 20:19
There should be an ID stamped on the set of carbs in question. It will either be on the flange below the choke handle or on the same flange on the outside of #4 carb. If you were to post what the ID is we should be able to tell you what they are.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Last edit: 30 Jan 2013 20:19 by gd4now.
- jarrad
30 Jan 2013 20:47
OH THATS AWESOME!!!
im picking them up whem i get back to NZ next week so ill post it up then.
thanks mate.
thanks mate.
79 z1000st BUILD:
R6 build:
KDX build:
79 z1000st BUILD:
R6 build:
KDX build:
- jarrad
04 Feb 2013 01:42
hey guys carbs have the following id.
112
6
112
6
79 z1000st BUILD:
R6 build:
KDX build:
79 z1000st BUILD:
R6 build:
KDX build:
- gd4now
04 Feb 2013 14:33
OK with that ID I would say they are VM28ss carbs, info I can find indicates they would of been a stock item on the 1980 KZ1000 D3 sold in the Canadian (non-US) market. As I understand it the D3s sold in the US had carbs marked with 1204 and those in Canada with 1126. They are both VM28ss carbs but the ones intended for the US market were jetting leaner to meet EPA standards, than those in other markets.
1977 KZ650 B1
- jarrad
06 Feb 2013 03:55
oh thats awesome to know, ill give them a clean up and sell them.
thanks mate.
thanks mate.
79 z1000st BUILD:
R6 build:
KDX build:
79 z1000st BUILD:
R6 build:
KDX build:
- badrhino
07 Feb 2013 22:02
I have a 1000J motor with 1100 top end and am planning on going with the BS34's I hope I can get them dialed in correctly.
What jetting should I start at?
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
Franken Z!
