- Thank you received: 391
Slow throttle return
- Motor Head
Can you push back on the throttle linkage at the carbs and have it slow down?
- Thank you received: 2829
- Richie7
Yes, I can slow it down by pushing the pulley manually. I can also feel that there is a resistance when I try to pull the pulley by hand.
Motor Head wrote: As suggested vacuum leaks are common for this. But also carb sync, or lean condition can cause this. Fuel levels and running vacuum sync should be checked.
1976 KZ900A4
98 CBR900RR Front End
01 GSXR1000 Swingarm + Wheel
Wiseco 1015cc Piston Kit
Dyna ignition + Accell Coils
VM28 Pumpers
- Richie7
650ed wrote: Ok; it sounds like you've tested for a lot of the usual causes already. Here's one other question - assuming you still have the push/pull throttle cables, when the idle hangs up if you twist the throttle to the "closed" position does the engine idle down immediately? Ed
1976 KZ900A4
VM28 Pumpers
- Motor Head
Otherwise sounds Lean, this will make it Hang at High Idle.
Did you recently change the Air Filter housing/ Box to "Pod's"?
- Kidkawie
- I bleed premix
- Thank you received: 245
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
- Richie7
The bike came with pods when I bought it, but the jetting was stock. It wasn't running right, so I re-jetted myself. 120 main, 22.5 slow, 1 1/4 turn out for mixture-screw, and needle clip in the middle.
The bike idles smooth and pulls hard at all speed except 1/8-1/4 throttle gives me out-of-gas symptom. I was going to play with the needle to see if I can get rid of the symptom, but slow return problem got in the way.
I think I ought to check everything from scratch.
Motor Head wrote: Since it will slow/ return with a bit of pressure on the linkage. Have you checked to see if there is still adjustment for the Idle Speed Screw? Can you still back it out and have the Idle drop? If not the Slides may well be adjusted to High on the Crossbar Linkage. This will keep them up, and not allow them to return fully.
1976 KZ900A4
VM28 Pumpers
- Richie7
650ed wrote: As Kidkawie suggested you may want to clean and lube the ignition advancer (if you haven't already done so). When they get sticky they can cause odd symptoms. Ed
1976 KZ900A4
VM28 Pumpers
- Richie7
Looks like I'm gonna have busy weekend. Fun
Kidkawie wrote: I'm not familiar with your carbs, but if you can: remove the carb caps and spray some WD40 around the slides, work the throttle while you're doing this to saturate the slides. Start it up and see if it changes. Otherwise, it's a vacuum leak or dirty advancer. You need to totally disassembele the advancer, clean and lube with some lightweight grease. You can't tell if it's dirty just by moving the weights with a screwdriver.
1976 KZ900A4
VM28 Pumpers
- baldy110
- Thank you received: 512
- Thank you received: 2098
Stock pilot jet is 17.5Richie7 wrote: Motorcycle:
1976 Kawasaki KZ900 A4
Carbs:
Mikuni 26mm with K&N oval filters(Main-120, Pilot-22.5, Needle clip-in the middle) Cleaned, rebuilt with new parts and lubed.
Problem:
Slow throttle return WHEN THE ENGINE IS RUNNING. Snaps right back when the engine is not running.
I can visually confirm that the throttle pulley slowly returns when it just hits the idle adjuster. The symptom is more obvious when I blip the throttle just a hair touch. All the linkages have been cleaned and lubed. I replaced the return spring. I checked all the places that relate to the linkage system, but no luck. The only thing I can think of is the throttle valves being worn out causing escaped air between the valves and carb bodies. Is this possible? I appreciate all your advises.
