- Thank you received: 512
dual throttle cable for kz750
- donthaveakawman
- Visitor
- baldy110
- donthaveakawman
- Visitor
- NakedFun
- Thank you received: 99
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
- donthaveakawman
- Visitor
- zukdave
- Thank you received: 229
tie it to your elbow then flap your wing's to fly.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
- wireman
- Thank you received: 299
its a freaking cv carb ,try lubing up the damn cable or maybe join a gym! :woohoo:
- donthaveakawman
- Visitor
- poolboy
- Thank you received: 1
www.amazon.com/2Wheel-Ride-GC-1-Motorcyc...rottle/dp/B0055QOKC8
:silly:
1980 KZ750H ,WG's carb rebuild, V&H 4-1 Exh ,WG wiremod, Dyna 3.0 ohm coils, Dyna-S EI DS2-2,New Bridgestones, O-ring Chain,
- wireman
- 78kztwin
donthaveakawman wrote: any ideas on a dual cable for 80 kz750 with keihin cvc carbs? my right arm is sore.
I'm sure someone will correct me if I'm wrong, but a duel throttle cable won't help with hand fatigue. The second cable stems from back in the day when the carbs had weak or no spring to close the carb causing them occasionally to stick open. Hence the creation of the duel or push/pull cable setup. Maybe some forearm exercises or a grip helper.
78 kz 750 twin work in progress
- gengomerpyle
- Thank you received: 17
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
