- Thank you received: 6
BS34 Carbs
- badrhino
21 Jan 2013 03:34 #568469
by badrhino
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
BS34 Carbs was created by badrhino
Do the BS34 carbs use a one cable throttle cable or two like the older ones?
Franken Z!
- gengomerpyle
- Thank you received: 17
21 Jan 2013 08:07 #568481
by gengomerpyle
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
Replied by gengomerpyle on topic BS34 Carbs
single
1982 GPZ750R1 ELR
1971 Honda CB750K
- Old Man Rock
- Thank you received: 225
21 Jan 2013 08:34 - 21 Jan 2013 08:35 #568483
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic BS34 Carbs
Granted, written for a set of Suzuki carbs :pinch: :laugh: but one of the best write ups I've found for the BS series....
Definitely something to learn from....
BS/CV 34 carb rebuild
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 21 Jan 2013 08:35 by Old Man Rock.
- badrhino
21 Jan 2013 18:13 #568543
by badrhino
Franken Z!
Replied by badrhino on topic BS34 Carbs
So if I switch to BS34's what do I do with the other cable coming from throttle. Also do the 34's require larger intake boots than the 29 smoothies?
Franken Z!
- wireman
- Thank you received: 299
21 Jan 2013 19:03 #568550
by wireman
Replied by wireman on topic BS34 Carbs
Yeah youll need carb boots off a j motor
