Wont start w/o starter fluid...Pod Filters!
- TexasBoot
17 Jan 2013 02:38 #567837
by TexasBoot
1980 550 Kawasaki
Wont start w/o starter fluid...Pod Filters! was created by TexasBoot
Ok I bought A 1980 KZ550A. It came with pod filters. 1st I cant get the bike to start with out using starter fluid and it runs great but when I come to a stop and put it in first the bike turns off when I try to get going agian.
2nd It has TK22 carbs and I've taken them apart and cleaned them up but they still do the same thing. I also have the 4 guage synchronizer but I dont know what I should tune them too. I think the carb is getting way too much air.
Ok now 3rd the carbs where jetted but to what I dont know. What size should my spark plugs be and what gap. I would be greatful if anyone can help me with any of theses problems.
1980 550 Kawasaki
- testarossa
- Thank you received: 82
17 Jan 2013 04:15 #567841
by testarossa
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
Replied by testarossa on topic Wont start w/o starter fluid...Pod Filters!
Are all four choke flaps in place and working properly?
2004 ZX-10R
Angola, IN
- loudhvx
- Thank you received: 1616
17 Jan 2013 16:53 #567909
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Wont start w/o starter fluid...Pod Filters!
There are two different manuals in my signature. You should download them both.
Also there is a link to TK-22 info. It has info on stock jetting etc.
As Testarossa said, the hard-starting is most likely the choke flaps.
Before getting too far into tuning, you will probably want to check the valve lash and a compression test. And then you will want to make sure the electrical system is working properly, including timing and voltage to the coils.
Jetting and tuning is really the last step in the process.
The TK-22's run fine with pods with proper jetting, but even with the stock jetting, the bike would still start, run, and be drivable. The main symptoms of under jetting would be stumbling while cruising at low to medium speed, and maybe some popping on the exhaust. Popping on the exhaust can also be an exhaust leak, or the air system failing, so that symptom,alone, may not be a jetting issue.
1981 KZ550 D1 gpz.
Other links.
The following user(s) said Thank You: TexasBoot
- TexasBoot
17 Jan 2013 21:30 #567938
by TexasBoot
1980 550 Kawasaki
Replied by TexasBoot on topic Wont start w/o starter fluid...Pod Filters!
I believe they are but I will check again
1980 550 Kawasaki
