34mm smooth bores
- rick1
16 Jan 2013 22:30 #567764
by rick1
34mm smooth bores was created by rick1
Hi my first post! Does anyone no where i can buy intake manifolds, for my
1981 kawasaki kz 1000 j. I want to use a set of mukuni 34 mm smooth bores.
But the stock intakes do not fit , need the intakes for mukuni carbs
Thanks for the help
Thanks for the help
- wireman
- Thank you received: 299
16 Jan 2013 22:42 #567766
by wireman
Replied by wireman on topic 34mm smooth bores
Are you sure they aren't 33 smoothbores?A set of carb boots for bs34 carbs off a j series bike might work for you.
That's a lot of carb for a stock motor
- rick1
16 Jan 2013 23:04 #567774
by rick1
Replied by rick1 on topic 34mm smooth bores
nope they are 34 mm mukuni carbs and no the intakes of an 1981 kz1000 J do not fit to small
thanks for the help
thanks for the help
- wireman
17 Jan 2013 00:18 #567804
by wireman
Do you have a picture of them?
- baldy110
- Thank you received: 512
17 Jan 2013 01:57 - 17 Jan 2013 01:59 #567832
by baldy110
Replied by baldy110 on topic 34mm smooth bores
Last edit: 17 Jan 2013 01:59 by baldy110.
- wireman
17 Jan 2013 16:29 #567906
by wireman
Oopsies,thought he was talking about an older 1000 with stock 26s/28s on it
- 4TheKZ1000
- Visitor
17 Jan 2013 16:56 #567910
by 4TheKZ1000
Replied by 4TheKZ1000 on topic 34mm smooth bores
I used J-Model Intake boots to attach my RS-34 Mikuni......???????
- turboking
- Thank you received: 106
17 Jan 2013 18:49 - 17 Jan 2013 18:50 #567919
by turboking
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
Replied by turboking on topic 34mm smooth bores
schnitz sells them for $20 each fits keihin's 33 smoothbore mikuni, rs series mikuni.
Kawasaki oem #16065-1135 . if memory serves me right these will fit the stock cv mikuni's
NOTE: these will not work for (stock)26mm 28mm or 29 mm smoothbores mikuni's (too big)
1985 GS 1150E
1983 GS 1100E
Last edit: 17 Jan 2013 18:50 by turboking.
- mtkawboy
- Thank you received: 16
17 Jan 2013 19:58 #567926
by mtkawboy
Replied by mtkawboy on topic 34mm smooth bores
Stock Mikuni Cv manifolds will work on 33s, I had a set on my bike
