- Thank you received: 1
Throttle cruise control
- poolboy
15 Jan 2013 12:55 #567464
by poolboy
1980 KZ750H ,WG's carb rebuild, V&H 4-1 Exh ,WG wiremod, Dyna 3.0 ohm coils, Dyna-S EI DS2-2,New Bridgestones, O-ring Chain,
Throttle cruise control was created by poolboy
Anybody have any info on a throttle cruise control for a 1980 KZ750-4 ltd, that will for sure work. thanks. sorry if this is the wrong forum for this!
- Thank you received: 1656
15 Jan 2013 13:49 #567471
by martin_csr
Replied by martin_csr on topic Throttle cruise control
I've never used one, but I have heard of the throttle rocker. There are probably youtube videos of the various products. Searching the internet for throttle rocker, I found a video of how one guy adjusts his throttlemeister... apparently, some folks have trouble figuring out how to use it.
- dshelly
- Thank you received: 5
15 Jan 2013 14:09 #567474
by dshelly
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
Replied by dshelly on topic Throttle cruise control
If you have two a two cable set up you could use a Vista Cruise. I have them on Both of my KZ1000's work great!
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- Killman
- Now with 99% more ducks
- Thank you received: 12
15 Jan 2013 14:31 #567478
by Killman
1983 kz440 ltd
Quack
Replied by Killman on topic Throttle cruise control
No eBay APP ID and/or Cert ID defined in Kunena configurationGot one right here:
1983 kz440 ltd
Quack
- cadmonkey
15 Jan 2013 15:20 #567486
by cadmonkey
'82 CSR 1000 a work in progress
'97 Suzuki bandit 1200 the daily ride
Replied by cadmonkey on topic Throttle cruise control
Ive got a vista throttle lock. I love it for those times when i just wanna rest my right hand for a minute.
compare.ebay.com/like/261094815148?var=l...ceItemTypes&var=sbar
- WABBMW
- Let The Good Times Roll !
15 Jan 2013 16:30 #567496
by WABBMW
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
Replied by WABBMW on topic Throttle cruise control
I've used an NP throttle lock, and also have a Cramp Buster. The cramp buster allows you to not have to use a constant grip on the round handle, thereby less tiring to certain muscles. Then the throttle lock can be used occasionally to simply let that right arm hang loose and relax for a little while. On flat terrain, it holds the speed within plus or minus several MPH.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
- rstnick
- Thank you received: 377
15 Jan 2013 21:53 #567568
by rstnick
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Replied by rstnick on topic Throttle cruise control
I have a Cramp Buster, which you use your palm to rest on to relax your grip.
Also have a Photon Cruise Control 2 ($18) which works great.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- poolboy
16 Jan 2013 13:20 - 18 Jan 2013 11:08 #567670
by poolboy
Replied by poolboy on topic Throttle cruise control
I sure like the Photon Cruise Control 2, just what I need, but cannot find it anywhere, been snooping all morning, lots down under but so far none in states, any suggestions. :woohoo:
found,its called "Go Cruise" on Amazon or elsewhere.
Last edit: 18 Jan 2013 11:08 by poolboy.
- Motor Head
- Thank you received: 391
18 Jan 2013 10:20 #567999
by Motor Head
Replied by Motor Head on topic Throttle cruise control
Vista Cruise lets you take your hand Off the Throttle. You can stretch your arm, rest your hand, or whatever. I have them on both my bikes. I wouldn't want to do a long full day without one.
Talked my buddy into one for his V Strom, he loves it.
