- Thank you received: 3
kz750e carb rebuild
- gixxerkidd03
www.cmsnl.com/kawasaki-1982-kz750-e3_mod...st/9535.html#results
1981 KZ750e
- donthaveakawman
- Visitor
- gixxerkidd03
1981 KZ750e
- lushbaugh
- everybodys a pro......
- Thank you received: 35
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
- donthaveakawman
- Visitor
- JR
- Thank you received: 449
gixxerkidd03 wrote: i just started rebuilding my 750 carbs and i was wondering if you guysa knew of any trick to getting the little o-ring gasket out of the pilot?? number 22 on this schematic. thanks
Dental pick or a 1st guitar string with a bend at the end. Sometimes it is difficult to see if a there is still an O ring down there so shine a light in the hole. Those O rings are tiny and fiddly and I have heard where previous owners did not put them in and so bike ran crappy. Once you get everything out clean the hole with a Q tip soaked in carb cleaner and blow it out to make sure no swab fibers are left.
Good luck
- donthaveakawman
- Visitor
- gixxerkidd03
lushbaugh wrote: hahaha it never is but its more feasible when your carbs arnt previously trashed.
and previously trashed they are. i manage to get the o rings and washers out of the first three pilot holes. but it looks like im in the market for a new outside right carb body thanks to someone using red lock tight on a brass fitting in cast aluminum. i drilled it perfect and with an easy out on a small "T" bar this was my outcome. anyone have and know where i can find a 82 kz750 e/h outside right carb body???
1981 KZ750e
- donthaveakawman
- Visitor
- gixxerkidd03
1981 KZ750e
- donthaveakawman
- Visitor
gixxerkidd03 wrote: i got three pilots out ( one is stripped). i got all three washers out and one and what looks lke 1 2/3 of another.it doesn't seem easy.
I don't know that there is a heli-coil that small available.
- donthaveakawman
- Visitor
