KZ650 C3 Accelerator Pump Cover
- diehard2k0
14 Jan 2013 23:35 #567385
by diehard2k0
KZ650 C3 Accelerator Pump Cover was created by diehard2k0
I picked up this gem a few months back and enjoyed riding it. It had a bad backfire from the carbs so I recently took them out and just finished cleaning and rebuilding them. Upon taking them apart, I noticed the housing on the accelerator pump was cracked. I noticed it while I was taking it off (I wound up just putting it back on since it wasn't leaking before, and hopefully doesn't anymore). Anywho, after a few hours online, I have been unable to locate this part. Does anyone know where I might be able to find it? It would be of great help. The bike is out of commission for a few weeks as I've sent the tank off to get much needed TLC (Rust started to eat through a corner near the front and massive rust inside the tank). I will keep my search going, but if anyone can point me in the right direction, I'd be a great help.
- Thank you received: 1656
15 Jan 2013 13:43 - 23 Jan 2013 14:35 #567470
by martin_csr
Replied by martin_csr on topic KZ650 C3 Accelerator Pump Cover
wrong info - my mistake
Last edit: 23 Jan 2013 14:35 by martin_csr.
15 Jan 2013 14:08 - 28 Jan 2013 12:51 #567473
by martin_csr
double post - delete
Last edit: 28 Jan 2013 12:51 by martin_csr.
- diehard2k0
15 Jan 2013 22:54 - 16 Jan 2013 00:03 #567586
by diehard2k0
Replied by diehard2k0 on topic KZ650 C3 Accelerator Pump Cover
Thanks Martin, but it's the cover that I need. I have the carb, and the diaphragms, but it's the cover on the accelerator pump that is shot. I will keep cruising the net till I find one. Unfortunately, we dont have a decent salvage yard for motorcycles here. On top of that, most of the riders here have crotch rockets or harley's. I've seen only a couple of cafe's, and most of them are Yamaha's. I've only seen one other KZ, which was a 750 if i'm not mistaken.
Here is a link to pictures of the crack.
imageshack.us/g/442/422d.jpg/
Last edit: 16 Jan 2013 00:03 by diehard2k0. Reason: added link to pictures
