Bike runs on PRIME but dies on RES or ON...
- jnymdnyt
13 Jan 2013 15:47 #567175
by jnymdnyt
John Elago
San Francisco, CA.
1978 KZ650
Bike runs on PRIME but dies on RES or ON... was created by jnymdnyt
Hi Everyone,
So I recently sold my other 78KZ650 SR and switch the carbs from my daily rider KZ650B2 to the one I sold (SR). I figured it's easier for me to tune the carbs on bike I use everyday than the one that sat for a while...so I thought. The SR carbs used the gravity feed petcock and the B2 uses the automatic petcock so I know the vacuum port has to be open so I removed the plug that was on it. The problem is the bike runs for a while on "res" or "on" position but will die after a while (after the bowls have been consumed, then if I put it on Prime it will start right up again. I don't think it's the fuel valve because it worked before switching the carbs. What am I missing here? Any input or feedback would be highly appreciated.
Thanks in advance.
Thanks in advance.
John Elago
San Francisco, CA.
1978 KZ650
- Nebr_Rex
- Thank you received: 300
13 Jan 2013 16:59 #567192
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic Bike runs on PRIME but dies on RES or ON...
Have you tried putting the vacuum line back on? :woohoo:
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Thank you received: 1656
13 Jan 2013 22:29 - 23 Jan 2013 14:03 #567233
by martin_csr
Replied by martin_csr on topic Bike runs on PRIME but dies on RES or ON...
never mind - misread reply
Last edit: 23 Jan 2013 14:03 by martin_csr.
