Velocity Stacks on a KZ550
- pwash13
09 Jan 2013 15:54 #566560
by pwash13
Velocity Stacks on a KZ550 was created by pwash13
Hey Folks,
So I recently picked up a 1980 KZ550A and have been working on it a good bit. I plan on changing the air intake and exhaust set up and one of the mods that I want to do is to put some velocity stacks on the carbs. I have been looking around on ebay and haven't really found any stacks that seem to be made for this bike. I read that these carbs have a 40mm diameter, so do I just need to pick up some 40mm diameter velocity stacks. Seems right to me, but I don't like returning things.......
Thanks,
Peter
Thanks,
Peter
- wireman
- Thank you received: 299
09 Jan 2013 16:56 #566572
by wireman
Replied by wireman on topic Velocity Stacks on a KZ550
Save your motor,install a set of pods or a stock airbox on there.
Anything smaller than a duck will get sucked right into the motor through the velocity stacks and do bad things to your carbs/motor
- pwash13
09 Jan 2013 19:32 #566608
by pwash13
Replied by pwash13 on topic Velocity Stacks on a KZ550
I know the risks of them, and I plan on putting some mesh in there to work as a filter also. That with the aid of a mud guard on the back should prevent most of the junk. All this being said, your comment is noted and 4 fresh K&N's are definitely a part of my thought process as well.
Thanks,
Peter
Thanks,
Peter
- wireman
09 Jan 2013 21:13 #566627
by wireman
Now this is interesting
Attachment images_2013-01-09.jpg not found
- zukdave
- Thank you received: 229
10 Jan 2013 00:47 #566654
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Replied by zukdave on topic Velocity Stacks on a KZ550
Koozie's on the stack's Brilliant.
I got a bunch from place's my bike's drank at.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- pwash13
10 Jan 2013 09:38 #566679
by pwash13
So it would seem like these stacks might fit on my carburetors..... my diameter is 40mm
compare.ebay.com/like/190764850340?var=l...ceItemTypes&var=sbar
- loudhvx
- Thank you received: 1616
10 Jan 2013 15:38 #566714
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Velocity Stacks on a KZ550
You'll probably be doing some rejeting, so you may want to check out the TK-22 carb info link in my signature.
Here's what I run. Zero maintenance, and never gunk up your leather gloves while adjusting idle speed etc. $8 each.
www.z1enterprises.com/ItemDetails.aspx?i...EMGO&item=EM12-55739
1981 KZ550 D1 gpz.
Other links.
- pwash13
10 Jan 2013 23:10 #566789
by pwash13
Thanks fellas,
Yeah, I searched this forum a while ago and bought some main jets already for what I should be running...... I'm not sure what size I bought but I found bookoos of info on the tekei carbs. Good work KZ Forum
-Peter
P.S. just for good measure I'll drop a couple photos to show you the bike
-Peter
- loudhvx
11 Jan 2013 13:04 #566849
by loudhvx
1981 KZ550 D1 gpz.
Other links.
looking good. should be a cool racer
1981 KZ550 D1 gpz.
Other links.
- mopguy
- Thank you received: 168
16 Jan 2013 21:09 #567741
by mopguy
Replied by mopguy on topic Velocity Stacks on a KZ550
A friend of mine runs the velocity stacks on his bike covered with nylon stockings.
