- Thank you received: 9
Strange Question....
- Spectre1982
09 Jan 2013 01:17 - 09 Jan 2013 01:18 #566476
by Spectre1982
1982 Kawasaki KZ750 Spectre
1978 Kawasaki KZ200
1985 Yamaha XV1000 Virago
(Avatar picture is from Alleycatscustoms.com)
Strange Question.... was created by Spectre1982
I have a horribly stripped pilot jet in my No. 4 carburetor that I fear is beyond extracting. I was reading on some forums about people using nitric acid to dissolve away the pilot jet that's stuck in the passage. Has anybody heard about this? It will obviously need a new jet.
Are the carbs on these old Kawa's made of Aluminum?
1982 750N1
1982 750N1
1978 Kawasaki KZ200
Last edit: 09 Jan 2013 01:18 by Spectre1982.
- wireman
- Thank you received: 299
09 Jan 2013 01:22 #566479
by wireman
Replied by wireman on topic Strange Question....
The carbs are die cast material on the older bikes,im guessing yours are the same.
Im not sure how youd keep it from affecting rest of carb body while eating away the jet.
Do you have a picture of it?
- Spectre1982
09 Jan 2013 01:44 #566485
by Spectre1982
1978 Kawasaki KZ200
Replied by Spectre1982 on topic Strange Question....
It's not supposed to react with Aluminum. It would probably tear up the die cast. That's off the table...
The extractor just twisted out more brass. It is stuck in there good. Not sure what else to try.
1978 Kawasaki KZ200
- wireman
09 Jan 2013 02:21 #566492
by wireman
Picture?
- z1kzonly
- Thank you received: 542
09 Jan 2013 02:29 #566494
by z1kzonly
Replied by z1kzonly on topic Strange Question....
Jig it up in a drill press with a machine vise. Then just drill it with progressive small drill bits till it is close and pick the rest of the brass out. Then send a tap down to clean it up. That's what I would do..
Or buy a set of carbs on ebay for 30-50 bucks, and use 1 of them.
The following user(s) said Thank You: guitargeek, wireman
- Thank you received: 2829
09 Jan 2013 10:28 #566520
by 650ed
Replied by 650ed on topic Strange Question....
I would soak it in Kroil for a couple days then try removing it. That stuff really does help. Ed
- steell
- Thank you received: 1656
09 Jan 2013 12:20 - 23 Jan 2013 14:12 #566532
by martin_csr
Replied by martin_csr on topic Strange Question....
never mind - my mistake
Last edit: 23 Jan 2013 14:12 by martin_csr.
- wireman
09 Jan 2013 12:43 #566534
by wireman
= heavy ass ,junk material. :laugh:steell wrote: die cast = pot metal = aluminum zinc alloy
- Spectre1982
09 Jan 2013 18:01 #566587
by Spectre1982
1978 Kawasaki KZ200
Finally got it with the extractor. I drilled it down pretty good and finally the extractor caught and pulled it out.
1978 Kawasaki KZ200
