YOSHIMURA can for 81 kz 750 H
- Rchenko
25 Dec 2012 12:46 #564633
by Rchenko
YOSHIMURA can for 81 kz 750 H was created by Rchenko
Does anyone know if it is possible to slip a yoshimura can onto the stock 4 into 1 pipes on my 81 kz 750? If so, what is the product number that will fit and would I have to re-jet? Any insight would be much appreciated. Cheers!
- lushbaugh
- everybodys a pro......
- Thank you received: 35
25 Dec 2012 13:19 #564639
by lushbaugh
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
Replied by lushbaugh on topic YOSHIMURA can for 81 kz 750 H
yes and no, i have swapped cans on lots of bikes, youll need to measure the pipe outside diameter and match it to the cans inlet inside diameter to be clean, then make your own bracket, so with a saw, decent midpipe ,can and some ingenuity maybe some band clamps yes. direct bolt on, no.
- guitargeek
- Thank you received: 50
25 Dec 2012 14:06 #564648
by guitargeek
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
Replied by guitargeek on topic YOSHIMURA can for 81 kz 750 H
1981 KZ750-H2 came stock with 4 into 2 pipes.Rchenko wrote: Does anyone know if it is possible to slip a yoshimura can onto the stock 4 into 1 pipes on my 81 kz 750? If so, what is the product number that will fit and would I have to re-jet? Any insight would be much appreciated. Cheers!
- trianglelaguna
- Thank you received: 235
25 Dec 2012 14:22 #564652
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic YOSHIMURA can for 81 kz 750 H
no
1976 KZ900
2003 ZX12R
2007 FZ1000
- 650mod
- Thank you received: 48
25 Dec 2012 16:12 #564655
by 650mod
78 kz 650 custom
Wiseco 720cc big bore
Dynajet stage 3 carb kit with pods
2002 Kawasaki Z750 exhaust
2001 Buell lightning front end
1999 Ninja 600 swingarm with 1999 Ninja 900 rear rim
converted to monoshock rear
Too many goodies to list fully
Replied by 650mod on topic YOSHIMURA can for 81 kz 750 H
I'm currently running a set of 4-1 pipes off a 2001 Kawi Z750 with a Yosh pipe on it on my 650. Like lushbaugh said, you'll have to make up mounting brackets and cut/adapt things to work. Make sure you measure all your outter diameters up for a starting point. Even after that, you'll need some high-temp silicone or muffler cement to seal everything up. It gives a really throaty growl :woohoo:
78 kz 650 custom
- trianglelaguna
25 Dec 2012 16:24 #564656
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
no
ah that would no for 800 alex...
like the guys before said.....
yes you can put a car engine in a kz200 you will just need to cut and weld a few things and maybe some silicone too.... :sick: :sick: :sick: :blink: :blink: :blink: :blush: :blush: :blush: :dry: :dry: :dry: :huh: :huh: :huh: :pinch: :pinch: :pinch: :side: :side: :side: :whistle: :whistle: :whistle: :evil: :evil: :evil: :ohmy: :ohmy: :ohmy: :blink: :blink: :blink:
this place sucks so bad this year
1976 KZ900
2003 ZX12R
2007 FZ1000
