are 29mm smoothbore carbs trading for enough to cover cost of conversion to fuel injection yet?
  • Duck
  • Duck's Avatar Topic Author
  • e vica na i sau na ga
23 Jun 2006 03:47
#56463
Have a set of 29mm smoothbores on the kz. Wondering if they have become desireable enough to cover the cost of conversion to a programmable management system and fuel injection components.
  • wiredgeorge
  • wiredgeorge's Avatar
Re: are 29mm smoothbore carbs trading for enough to cover cost of conversion to fuel injection yet?
23 Jun 2006 06:31
#56496
If you sold them on eBay, YOU would get about $350. If you bought FI junk, which would include throttle bodies, the management system and a cylinder head, how much would YOU expect to pay? Perhaps you could luck out and work a swap with an FI owner but if you design/build your own system, it will end up costing more I expect than your your 29s will bring.
  • solomrus
  • solomrus's Avatar
23 Jun 2006 08:02
#56529
the cold, hard truth is that they probably won't.
350 would be a start, and not that good of a start.
--r
198o kz1ooo Bravo Four
  • Duck
23 Jun 2006 09:08
#56547
Thanks.
I guess the EFI will have to wait for further appreciation of these MICs. Will keep looking for an abandoned megasquirt project.
  • steell
  • steell's Avatar
23 Jun 2006 09:34
#56556
MegaSquirt EFI controller $140
GSXR Throttle bodies $50
Fuel pump free (off a 87 F150, already had it)
Engine temp sensor, free from junkyard.
Air filters will need to be adapted, but I'm not at that point yet, although I may be able to use the stock air box.
Obviously, if you are a cheapskate like me, EFI can be cheaper than a set of 29mm smoothbores :D
I don't know why you would need to replace the cylinder head.
Gonna have to drag WG kicking and screaming into the 21st century I guess
:evil: :laugh:
  • Duck
23 Jun 2006 13:29
#56602
:evil: :laugh:
Yep, I'm cheap. Tight as a tick. Will keep looking. Do GSXR throttle bodies need any mods as far as spacing? Every time I put gas in I think..."man, if I had full electronic engine management, I'd be getting at least 45MPG".
  • steell
  • steell's Avatar
23 Jun 2006 16:06
#56642
Yep, you have to change the spacing and either modify the fuel rail or get/make another one.
GPz1100 throttle bodies will bolt right on, but people have been bidding them up to stratospheric levels on eBay lately :(
Post edited by: steell, at: 2006/06/23 19:07
