Mikuni 28mm vs 29mm smoothbore
- wireman
Re: Mikuni 28mm vs 29mm smoothbore
23 Dec 2012 21:11
Well those are the better looking 28s,not the smog carbs from 79-80. :laugh:
- mopguy
24 Dec 2012 15:37
Thankyou all for your input and Merry Christmas and Happy New year to all members.
- KZB2 650
25 Dec 2015 08:04
The 29s are a after market carb and did not come stock on any model ........ search for em on here....
should come up with a lot of good info.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
The following user(s) said Thank You: Nessism, peter1958
25 Dec 2015 08:15 - 25 Dec 2015 08:16
If you are trying to find a set of smoothbores look for the brass bead showing in the rectangle on the carb as shown in the red circle below. Ed
Attachment Smoothbore-3.jpg not found
Last edit: 25 Dec 2015 08:16 by 650ed.
- peter1958
25 Dec 2015 08:23 - 25 Dec 2015 08:24
lose 20 pounds and you will have more power
www.kzzone.com/
Last edit: 25 Dec 2015 08:24 by peter1958. Reason: o
The following user(s) said Thank You: PLUMMEN
25 Dec 2015 08:29
:woohoo:
- peter1958
25 Dec 2015 08:40 - 25 Dec 2015 08:43
My elr got real fast I lost about 30 lbs and isnt like 1lb a tenth in the 1/4 mile best improvement in my bike
www.kzzone.com/
Last edit: 25 Dec 2015 08:43 by peter1958. Reason: j
- peter1958
25 Dec 2015 08:48
I have used just about every carb every mod and every mod exept frame mods for speed easy to just lose some of your own weight isnt it. I must have 13 bikes 50 sets of carbs and a little common sense. Oh and an empty bottle of wine cheers
www.kzzone.com/
- floivanus
25 Dec 2015 10:38
I REALLY don't get this fascination with people and 29s, they are expensive, work a little better offer an extra millimeter of venturi size, and are expensive OLD tech, if you insist on paying $700+ on a set of carbs, get something modern, adapt a set off a gsxr, or a newer ninja, buy actual NEW carbs or just do an EFI swap and forget tuning.
You have 3 basic setups for 29s, kz, suzuki gs, and honda cb750; z1enterprises had/has a page on identifying the differences.
Past; 78 kz1000, 83 kz550
Andrew
Andrew
- eddiem
- KZR FLAG RELAY CARRIER #63
25 Dec 2015 11:23
I agree with you but I like running the air box. Is it possible to run the air box with newer carbs?
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
25 Dec 2015 13:30
- eddiem
25 Dec 2015 14:11
cool....gave me an idea. Thanks Steve
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
