VM24ss 1.75 cutaway spring??
- NickMac
23 Dec 2012 03:53 - 27 Dec 2012 23:08 #564199
by NickMac
VM24ss 1.75 cutaway spring?? was created by NickMac
I stripped my vm24ss carbs so I could dip them in the paint can carb cleaner. I'm having some issues getting two parts off. One is the bottom O-ring on the accelerator pump post that protrudes into the bore (see picture). The second is the plastic piece on the outside of the slide bore (opposite slide guide/see pic).
1) Any tips on removal is much appreciated
2) Is it necessary to remove these parts for the carb dip?
3) Is the carb dip appropriate if these parts can not be removed?
thanks!
thanks!
Last edit: 27 Dec 2012 23:08 by NickMac.
- Thank you received: 1656
23 Dec 2012 17:26 - 23 Jan 2013 13:54 #564299
by martin_csr
Replied by martin_csr on topic VM24ss accelerator pump valve removal?
The pump nozzles are press fit into the carb body.
As for the 2nd photo, that plastic "plug" is new to me - no one has ever mentioned it that I recall.... never noticed that before, but my 81 650's carbs have it.
Last edit: 23 Jan 2013 13:54 by martin_csr.
- NickMac
23 Dec 2012 17:55 #564306
by NickMac
Replied by NickMac on topic VM24ss accelerator pump valve removal?
I was planning on using the autozone special. I think the brand starts with a B like Barrymore or something similiar.
Do you think it will hurt if i tape the O-ring off then dunk them or should i just go for gold and dunk the body with the O-ring exposed?
Thanks
Thanks
- wireman
- Thank you received: 299
23 Dec 2012 19:01 #564319
by wireman
Replied by wireman on topic VM24ss accelerator pump valve removal?
Berrymans,make sure to rinse the parts really good with aerosol carb cleaner after soaking them in the berrymans.
The berrymans Ive got leaves a film like thin syrup if you don't rinse parts really good after soaking them
23 Dec 2012 20:50 - 23 Jan 2013 13:57 #564351
by martin_csr
I would replace the o-rings. A HarborFreight etc metric o-ring kit should have a size that's close enough. I replaced the pump nozzle, main-jet/bleeder-pipe, & drain screw o-rings from a HF kit.
Last edit: 23 Jan 2013 13:57 by martin_csr.
- NickMac
27 Dec 2012 18:29 #564888
by NickMac
Replied by NickMac on topic VM24ss 1.75 cutaway spring??
Went to harbor freight and the o-ring kit was perfect! thanks for the suggestion.
NOW, Im trying to reasmble my carbs and the valves have a cutaway of 1.75. There are 2 rubber bumpers and a spring that im not sure how to assemble. the valves have a larger diameter needle hole to accomodate this spring. I have another set of vm24ss and they have 1.5 cutaway and did not have space for spring and no bumpers upon comparative dissasemble. See pics for comparison
Further, those parts are not seen on any diagrams or in any rebuild kits i have been able to find.
Thanks!
Thanks!
28 Dec 2012 17:55 - 23 Jan 2013 13:54 #565006
by martin_csr
Replied by martin_csr on topic VM24ss 1.75 cutaway spring??
I don't know how those parts fit. You could try the diagrams at PowerSportsPlus.com for various KZ650s.
- NickMac
28 Dec 2012 23:38 #565030
by NickMac
You are a life saver.
Thanks again
martin_csr wrote: I don't know how those parts fit. You could try the diagrams at PowerSportsPlus.com for various KZ650s... perhaps the 1977 C1 or 1981 H1 to start?
Thanks again
29 Dec 2012 23:19 - 23 Jan 2013 13:55 #565112
by martin_csr
Check the accelerator pump by supplying fuel to the carbs & prime the pump circuit, then actuate the throttle pulley vigorously: fuel should squirt out the pump nozzles straight back without hitting the carb bore walls.
Last edit: 23 Jan 2013 13:55 by martin_csr.
