- Thank you received: 1
Will 83 KZ750 LTD carbs work on an 80 KZ750 E?
- 2ndgenKZ
- 750 LTD
Both are Keihin CV34's, different models
I know that the number of jets are different. The carbs from the LTD have only a single jet, where the E model has a primary and secondary jet (for quarter throttle control).
May not run as well but would they work if jetted the LTD carbs?
1983 Kawasaki KZ750 LTD MAC
1983 Kawasaki KZ750 LTD BONES
1981 KZ750E KERKER
1985 Dodge Conquest FLATTY
1995 Jeep Cherokee RUSTY
- Thank you received: 1656
I think all of the 750-4 airboxes are pretty much the same. Some had a paper filter, but the later ones had a foam filter that requires oiling. Not sure how much of a difference that makes for carb adjustments.
- donthaveakawman
- Visitor
- donthaveakawman
- Visitor
- 2ndgenKZ
- 750 LTD
1981 KZ750E KERKER
- DoubleDub
- Visitor
The 550 is a different engine.donthaveakawman wrote: what I want to know is will a kz550 bottom end work with a kz750 top end, ...
- donthaveakawman
- Visitor
My kz750 h1 occasionally gets a stuck slide, and when it breaks free it is good to have my hand near the clutch.
The main issue you need to deal with is finding a throttle cable and the measurements of the carburetors for the carburetor holders. :woohoo:
- DoubleDub
- Visitor
donthaveakawman wrote: keeping in mind that torque is made more so with a larger crank, and power is made more so with a larger bore.
:huh:
- donthaveakawman
- Visitor
