- Thank you received: 10
Does separting carbs throw them out of sync?
- Kitten Tooth
21 Dec 2012 16:52 #563939
by Kitten Tooth
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
Does separting carbs throw them out of sync? was created by Kitten Tooth
I had a mechanic tell me that separating the carburetor bodies on any bike will throw them out of sync with each other. I never separated another set of carbs since then and it sucks because i like to really clean the hell out of them whenever i have them off of a bike. I got to looking at the carbs on my 81' KZ1000LTD and was wondering why this would be true.. all the linkages for the butterflies just pop into each other through a spring loaded plate.. if the adjusting screws for syncing them arne't messed with when the carbs are apart why would things be any differen't apon re-assembly?
Thanks Guys,
KT
Thanks Guys,
KT
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- bountyhunter
- Thank you received: 337
21 Dec 2012 17:41 #563944
by bountyhunter
Replied by bountyhunter on topic Does separting carbs throw them out of sync?
Yes, it can and probably will. The two throttle plates have to be synced mechanically so they are open the same amount at low throttle openings or low speed performance will be screwed up. That's done by physically changing the position of the throttles with respect to each other. Separating them disconnects that connection.
- Kitten Tooth
21 Dec 2012 22:40 #563978
by Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
Replied by Kitten Tooth on topic Does separting carbs throw them out of sync?
Ahh alrighty then. makes sense. Thanks man
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Thank you received: 1656
22 Dec 2012 15:17 - 23 Jan 2013 13:57 #564087
by martin_csr
Replied by martin_csr on topic Does separting carbs throw them out of sync?
If they needed it, I would go ahead & separate 'em... may as well do the complete job & not have that nagging doubt in the back of the mind.
Last edit: 23 Jan 2013 13:57 by martin_csr.
- kzz1king
- Thank you received: 52
22 Dec 2012 19:14 #564117
by kzz1king
Home built KZ1000 turbo setup
Replied by kzz1king on topic Does separting carbs throw them out of sync?
I agree, it is not like they cannot be synced again.
- 893cv
- Thank you received: 15
22 Dec 2012 19:23 #564123
by 893cv
1980 kz1000 LTD
1978 Z1R
Replied by 893cv on topic Does separting carbs throw them out of sync?
If you need to separate the carbs to get them clean then do it. It only takes a few minutes to sync the carbs. I have a Carbtune sync tool and use it at almost every oil change. If you are going to keep and ride almost any "older" motorcycle a Carbtune is a must have tool.
1980 kz1000 LTD
1978 Z1R
