- Thank you received: 1
29 smoothbore needle valve assembly
- IGO202
28 Nov 2012 12:27 #560332
by IGO202
29 smoothbore needle valve assembly was created by IGO202
I'm going thru a set of 29's I've had for over thirty years. I've lost one needle valve and trying to find out if I need the 2.5 or 2.8 assembly.
I cannot find any markings on mine anywhere.
Any ideas or input would be much appreciated.
Thanks,
Dan
Thanks,
Dan
- 4TheKZ1000
- Visitor
28 Nov 2012 14:01 #560341
by 4TheKZ1000
Replied by 4TheKZ1000 on topic 29 smoothbore needle valve assembly
didnt know they had a 2.8 ..... all mine are maked 2.5 .... :huh:
- z1kzonly
- Thank you received: 542
28 Nov 2012 20:10 - 28 Nov 2012 20:12 #560374
by z1kzonly
Replied by z1kzonly on topic 29 smoothbore needle valve assembly
Stock had 2.0 and 2.3, I needed a magnifying glass.
should be marked on the lip, right were the needle drops in.
I have these on ebay tonight.
Last edit: 28 Nov 2012 20:12 by z1kzonly. Reason: picture added
- 4TheKZ1000
- Visitor
28 Nov 2012 20:16 - 28 Nov 2012 20:26 #560376
by 4TheKZ1000
Z1-E is showing 2.5 only ......not 2.0 or 2.3
SU002-503 - Mikuni Needle Valve Assembly 2.5
- OEM: N122.032 - Fits 29mm and 33mm Mikuni smoothbore carbs - VM29 & VM33
_____________________________________________________________________________
SUDCO shows only 2....shown below.
Applications: VM29 & VM33 Smoothbore
Size Application Mikuni No. Order No.
(2.5) N122.032 002-503
(2. Std on VM29 & VM33 N122.032 002-504
Washer for Needle Valve Seat BS34/52-0.5 002-187
Filter for Needle Valve Seat VM18/233 002-606
Last edit: 28 Nov 2012 20:26 by 4TheKZ1000.
- Jeff.Saunders
28 Nov 2012 22:25 #560394
by Jeff.Saunders
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
Replied by Jeff.Saunders on topic 29 smoothbore needle valve assembly
2.5 was used on all the VM29's for KZ's and GS's.
Z1 Ent on Facebook,
- IGO202
29 Nov 2012 01:47 - 29 Nov 2012 01:53 #560418
by IGO202
Replied by IGO202 on topic 29 smoothbore needle valve assembly
Thanks guys for the help, I'll order a 2.5 tomorrow.
I had called Sudco but the tech could not help.
I really appreciate the info!
Dan
Dan
Last edit: 29 Nov 2012 01:53 by IGO202.
- Thank you received: 2098
29 Nov 2012 05:05 #560432
by Patton
Replied by Patton on topic 29 smoothbore needle valve assembly
