What to clean carbs with?
  • kzz1king
  • kzz1king's Avatar Topic Author
25 Nov 2012 16:38
#560021
I found a set of 28's in my shop from a 75. I say found because I thought I sold them. Hope someone didn't get 26's that thought they were getting 28's!! I found a lot of good info in the archives but am looking for something too soak them in that is not to aggressive. I just want them to look a bit better cosmetically.
Also what is a good setting for needle and size of mains for pods and header?
Thanks
Wayne
Home built KZ1000 turbo setup
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: What to clean carbs with?
25 Nov 2012 16:45 - 26 Nov 2012 10:33
#560023
1. Walmart....sells 1-gallon cans of Berrymans carb cleaner with dip basket....I like it.
2. Disassemble carbs and soak over night in cleaner....replace lid during process. Dont do in house.
3. remove and place parts in a bucket of hot soapy water and scrub parts....
4. rinse well with clean water and use compressed air to blow out passages and dry parts.
If you want a factory look on the exterior....soda blasting is the best way to get there. I would soda blast them after step 4 and then do step 3 and 4 over.
Attachment 0007589400996_500X500.jpg not found
Attachment VM29001.JPG not found
Last edit: 26 Nov 2012 10:33 by 4TheKZ1000.
  • P21
  • P21's Avatar
25 Nov 2012 18:52
#560033
Kawasaki KZ 1000 Police (2002) P21
  • Nebr_Rex
  • Nebr_Rex's Avatar
25 Nov 2012 19:15
#560034
Pine Sol,maybe dish soap?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • 0Z.Z1R Mk2
  • 0Z.Z1R Mk2's Avatar
26 Nov 2012 08:16
#560108
100% straight white vinegar is a good alternative as well....
Soak overnight and clean with a tooth brush for that o'natural Finnish.
Before.... :(
And after... :woohoo:
1976 KH 500 triple
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
1982 GSX 1000S Katana
1983 GSX 1000S Katana
Don't knock my turbo lag - it gives your naturally aspirated a chance..
The following user(s) said Thank You: Patton
  • XXWoodmanXX
  • XXWoodmanXX's Avatar
26 Nov 2012 13:53
#560129
a lot of auto part stores have the Gunk version of Berrymans also . Around $25 tho. I've also had good luck with straight Pine Sol. Seems to get parts nice and shiny :P
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
26 Nov 2012 14:53
#560131
PineSol followed with soda blasting will give you an original finish.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • lushbaugh
  • lushbaugh's Avatar
  • everybodys a pro......
26 Nov 2012 15:50
#560134
that tub o filth looks me after work....
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
  • wagonmaster69
  • wagonmaster69's Avatar
  • 78 KZ1000A2 / 82 KZ1100 Spectre
27 Nov 2012 02:13
#560196
0Z.Z1R Mk2 wrote: 100% straight white vinegar is a good alternative as well....
Before.... :(
You take it apart or did you leave it together.
  • 0Z.Z1R Mk2
27 Nov 2012 06:20
#560206
wagonmaster69 wrote: Did you take it apart or did you leave it together?
Took it apart of course... :P
I must add that the vinegar method may not be suitable for cleaning old fuel varnish.
But did a great job on the carb bodies.
1976 KH 500 triple
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
  • martin_csr
  • martin_csr's Avatar
27 Nov 2012 09:53 - 23 Jan 2013 13:00
#560218
Others have used lemon juice, but one guy reported that it kinda corroded the parts.
PineSol is supposed to be non-corrosive & it is an oil solvent. I've used a hot water solution of it on a couple of fuel valves w good results.
The Berryman's usually available now is the California compliant formula... less toxic & not as effective as the original/professional blend. I have a can of the good stuff & used it on some carbs.
Last edit: 23 Jan 2013 13:00 by martin_csr.
27 Nov 2012 10:00
#560220
Others have reported successful results from boiling in plain water.
Good Fortune! :)
