- Thank you received: 8
kz750 carbs work on 750 spectre
- rcook52459
16 Nov 2012 15:57 - 16 Nov 2012 15:58 #558665
by rcook52459
1983 750 spectre,all stock almost 16,000 on it on 1980 Suzuki gs1000l
kz750 carbs work on 750 spectre was created by rcook52459
wondering if carbs from a 82 kz750ltd fit on my 83 750 spectre.i know the jets are bigger in the 750ltd carbs,but that's all i know about them
Last edit: 16 Nov 2012 15:58 by rcook52459.
- OldSchoolZ
- Thank you received: 33
16 Nov 2012 16:15 #558669
by OldSchoolZ
Remember, don't work on your bike so much you never ride it.
Replied by OldSchoolZ on topic kz750 carbs work on 750 spectre
Good possibility you can make them work.
- Del_Herring
- Thank you received: 29
16 Nov 2012 17:06 #558675
by Del_Herring
1983 KZ750-N2 Spectre
Replied by Del_Herring on topic kz750 carbs work on 750 spectre
Would imagine that should be a relatively simple swap. Same engine, so the spacing and all is the same. As far as I know the cams and such are all the same too. So I can't see why they wouldn't work.
- Nebr_Rex
- Thank you received: 300
16 Nov 2012 17:19 #558678
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic kz750 carbs work on 750 spectre
Kiehin and Mikuni carb boots are different.
I know the Ltd carbs will be Kiehin and the Spectre should be also,only painted black.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Del_Herring
16 Nov 2012 18:36 #558695
by Del_Herring
Yea, Spectres are Keihins.
Still curious about the jetting change, woulda thought being the same carbs they'd be the same. Maybe a change for the exhausts if they're different or some such.
- Del_Herring
16 Nov 2012 18:41 #558696
by Del_Herring
Anyone know if they're the same diameter keihins? Can measure mine when I get home if needed. I would think they're the same, just trying to think through reasons for the jet change. If they're the same carb, you can always just swap jets around if needed.
- Nebr_Rex
17 Nov 2012 00:30 #558743
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
Carbs are the same,mufflers are different.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Thank you received: 1656
17 Nov 2012 10:35 #558778
by martin_csr
Replied by martin_csr on topic kz750 carbs work on 750 spectre
The carburetor holders & airbox ducts are the same, so the carbs are probably a direct swap.
- rcook52459
17 Nov 2012 19:15 #558836
by rcook52459
Replied by rcook52459 on topic kz750 carbs work on 750 spectre
thanks for the info
