- Thank you received: 1
Leaking fuel from carb - '77 kz400 deluxe
- jona barish
11 Nov 2012 20:53 #557966
by jona barish
'77 kz400
Leaking fuel from carb - '77 kz400 deluxe was created by jona barish
Hi all, the latest of what seems like a never ending string of problems on my '77 KZ400 Deluxe has been that my left carb is leaking a significant amount of fuel through the overflow tubes. The engine still runs fine and idles normally while this is happening (although I shut it off as soon as I noticed the leak). I have also noticed significant fouling on the spark plugs.
Is this more than likely a float/needle issue?
I've never done any carb work. If someone has a good step by step walkthrough of how to troubleshoot this, that would be awesome
Thanks!
Thanks!
'77 kz400
- Topper
- Thank you received: 133
12 Nov 2012 00:36 #557991
by Topper
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
Replied by Topper on topic Leaking fuel from carb - '77 kz400 deluxe
It sounds like it's probably the valve needle. That's what stops the fuel from flowing into the carb bowls when they fill up.
1979 KZ750 Twin
