Carb Info Smoothbores
- Z Parts
10 Nov 2012 13:37 #557767
by Z Parts
Carb Info Smoothbores was created by Z Parts
I bought a 1974 Z900 and was told it has 29 smoothbores on it. Is their a way to ID them wihtout taking them off the bike.
- 4TheKZ1000
- Visitor
10 Nov 2012 13:49 - 10 Nov 2012 14:03 #557771
by 4TheKZ1000
Replied by 4TheKZ1000 on topic Carb Info Smoothbores
post a pic on here of both sides.....
on this first pic...see the small square down by the float bowl....that a key feature..
On the second pic....see all the circles located inside the inlet...dead giveaway.
Attachment VM29004-Copy.JPG not found
Attachment VM29002.JPG not found
Last edit: 10 Nov 2012 14:03 by 4TheKZ1000.
- Thank you received: 2098
10 Nov 2012 14:34 #557780
by Patton
For more details and variations among earlier and later Z1 carbs and smoothbore carbs,
click > www.z1enterprises.com/Z1CarbGuide.aspx
Replied by Patton on topic Carb Info Smoothbores
The following user(s) said Thank You: Z Parts
- gd4now
- Denco where did you go?
- Thank you received: 445
10 Nov 2012 16:56 #557790
by gd4now
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Replied by gd4now on topic Carb Info Smoothbores
Agree all of the things pointed out by others are true of the vm29s, other that not all of them have the large drain plug, the very early ones have the smaller side facing drain screw.
I would add that there should be an ID stamped on the flange either below the choke lever on carb #1 or on the same location on the outside of #4. The 29s will be one of the following.
29/A2, or 29/A7, or 29/A12
1977 KZ650 B1
The following user(s) said Thank You: Z Parts, wireman
- uglee
- New 2da game but Tru 2this thang!!!!!
15 Nov 2012 12:14 #558465
by uglee
Replied by uglee on topic Carb Info Smoothbores
Are these smooth bores?
Attachment IMG_20121114_180633_2012-11-15.jpg not found
- uglee
16 Nov 2012 19:15 #558701
by uglee
All the kz gurus and no thougjts?? Sold $10
- 4TheKZ1000
- Visitor
16 Nov 2012 20:36 #558714
by 4TheKZ1000
yes they are.....
- uglee
16 Nov 2012 22:42 #558730
by uglee
So for throwing $10 bucks extra on a package deal I scored big time...... Thanks 4 the nod
- 4TheKZ1000
- Visitor
16 Nov 2012 22:43 #558731
by 4TheKZ1000
uglee wrote: So for throwing $10 bucks extra on a package deal I scored big time...... Thanks 4 the nod
