Missing choke plates
- cronk
09 Nov 2012 18:47 #557659
by cronk
1982 KZ-550
Missing choke plates was created by cronk
I pulled apart my carbs and am unfourtuantly missing the choke plates. Just having some difficulty sourcing the part to replace them. Does anyone have any known sites? 82 kz550
1982 KZ-550
- KZQ
- Administrator
- Thank you received: 1415
09 Nov 2012 19:12 - 09 Nov 2012 19:12 #557660
by KZQ
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Replied by KZQ on topic Missing choke plates
Welcome to Z Jungle!
There never were any choke plates. These bikes use enricher circuits to start when cold.
Bill
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Last edit: 09 Nov 2012 19:12 by KZQ.
- cronk
09 Nov 2012 19:54 #557667
by cronk
- KZQ
- Administrator
09 Nov 2012 22:31 #557693
by KZQ
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
My mistake! I stuck my finger into the throat of one of my 550 carbs and cut it off for you. Where shall I send it?
Sorry
Bill
Sorry
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
- KZQ
- Administrator
09 Nov 2012 22:37 #557695
by KZQ
Need someone more familiar than I with 550's. My 1980 550 has plain old choke plates that pivot on a shaft. cronk's 1982 appears to have slides of some sort.
BILL
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
cronk wrote: What are these for?
BILL
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
- loudhvx
- Thank you received: 1616
10 Nov 2012 12:58 - 10 Nov 2012 13:02 #557758
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Missing choke plates
All of the TK-22 carbs, which were used on the first generation of 550 motors, use choke plates.
In my signature, I have a website for those carbs. There are some notes on preventative maintenance for the choke plates... checking hinges etc.
But once the flaps are gone, you will have to either make some flaps, get some from somewhere (almost impossible without buying another set of carbs), or completely block off the plate openings and go with totally manual choke. Totally manual chokes will require you to play with them more until the bike warms up. However, if you rejet the pilots, the bike will not need nearly as much choke.
KZrider has several threads on people making their own flaps, or doing the plate block-off with epoxy etc.
The details for rejetting the pilots is on my site as well.
1981 KZ550 D1 gpz.
Other links.
Last edit: 10 Nov 2012 13:02 by loudhvx.
- apbling
- Thank you received: 12
10 Nov 2012 14:26 #557777
by apbling
Replied by apbling on topic Missing choke plates
If you search my posts I have a thread where I made some functional (but not pretty ) plates out of some thin stainless steel shims that are used to leveling industrial electric motors. However, any rigid piece of metal you can cut or use a dremel on should work. I cannot believe I used to ride this bike without the plates! I had no plates at all to start for a few years. It sucked. Then I blocked them off completely, but I had to constantly fiddle with the choke and find the sweet spot. It was almost more work than no plates. I'd suggest find yourself some thin metal somewhere, make yourself a template with a piece of paper or cardboard or whatever and start making some. Word of caution...be careful with the springs and the pins. I broke a spring and had to modify it a bit because just like the flaps, the springs aren't just laying around and guys that have them usually want to keep them for their own use.
- cronk
12 Nov 2012 18:03 #558084
by cronk
1982 KZ-550
Replied by cronk on topic Missing choke plates
sounds good looks like ill be making my own.
as i'm not paying 100 a pop for 4 new choke slides which were all i could find.
thanks for the info guys.
1982 KZ-550
