- Thank you received: 5
Choke Spring placement? (resolved, i'm a dolt)
- jbeebe1
04 Nov 2012 12:34 - 04 Nov 2012 13:01 #557010
by jbeebe1
79 Honda 400 Hondamatic
79 Honda CB650
81 Honda CX500
81 Honda Passport C70
others coming in and out all the time!
Choke Spring placement? (resolved, i'm a dolt) was created by jbeebe1
Hey everyone, so i finally narrowed down my leaking carbs to cracked overflow tubes. i'm still determining the best way to solder them, so any advice is appreciated:
www.kzrider.com/forum/11-projects/551488...t=20&start=40#557009
But i somehow popped off the choke spring that links to the other carb's choke lever. So without the spring hooked onto the other choke's lever, only the one side moves. The FSM only states to hook it on, but i fiddled with it for 30 minutes and still can't figure it out. Could anyone explain or take a close-up pic of theirs and post it? Thanks guys:
You can see the spring hanging down, unsure of how it hooks onto the lever. I tried just hooking onto the "outside" of it where it looks most apparent, but then it doesn't allow the choke to return. Does the spring hook on from the "outside" or the "inside" of the carb body?
79 Honda CB650
81 Honda CX500
Last edit: 04 Nov 2012 13:01 by jbeebe1.
- wireman
- Thank you received: 299
04 Nov 2012 12:55 #557011
by wireman
Replied by wireman on topic Choke Spring placement?
Try spinning it towards front of carbs same direction its going now to see if that keeps tension on spring then hook into that little slot to hold it
- jbeebe1
04 Nov 2012 13:00 #557012
by jbeebe1
Bingo Bango: man, it seems so simple now that I did it, sometimes you just need an outside brain after over-thinking it for so long.
79 Honda CB650
81 Honda CX500
Replied by jbeebe1 on topic Choke Spring placement?
wireman wrote: Try spinning it towards front of carbs same direction its going now to see if that keeps tension on spring then hook into that little slot to hold it
79 Honda CB650
81 Honda CX500
- wireman
04 Nov 2012 14:02 #557018
by wireman
Ive done much wose things,just ask my wife shes got a book! :sick: :woohoo:
