petcock problems/swap
Re: petcock problems/swap
27 Oct 2012 00:09 - 27 Oct 2012 00:09The unnumbered spring metal washer ring goes between the lever and cover plate, as shown in the diagram.jbeebe1 wrote: ...on the lever side of the petcock there is a metal washer/ring. Does that go in between the lever and the rubber gasket, or between the lever and the cover plate?....
Last edit: 27 Oct 2012 00:09 by Patton.
- jbeebe1
27 Oct 2012 00:20Patton wrote:The unnumbered spring metal washer ring goes between the lever and cover plate, as shown in the diagram.jbeebe1 wrote: ...on the lever side of the petcock there is a metal washer/ring. Does that go in between the lever and the rubber gasket, or between the lever and the cover plate?....
Ok I had it separating the lever and the gasket. Could that have caused my problem?
79 Honda 400 Hondamatic
79 Honda CB650
81 Honda CX500
81 Honda Passport C70
others coming in and out all the time!
79 Honda CB650
81 Honda CX500
27 Oct 2012 00:32jbeebe1 wrote:Patton wrote:The unnumbered spring metal washer ring goes between the lever and cover plate, as shown in the diagram.jbeebe1 wrote: ...on the lever side of the petcock there is a metal washer/ring. Does that go in between the lever and the rubber gasket, or between the lever and the cover plate?....
Could have let the gas flow like the Amazon no matter the lever position or if the bike is running or not. :lol:
Hoping gasket 11009A hasn't been damaged.
- jbeebe1
27 Oct 2012 02:01
haha it appears to still be in good shape. I'll update as soon as I can put it back in the tank and test it out. Probably not until after the weekend.
79 Honda CB650
81 Honda CX500
79 Honda CB650
81 Honda CX500
- lushbaugh
- everybodys a pro......
27 Oct 2012 03:58
Yes if that spring washer is where you had it that will cause the seal to warp and create a channel. you may be good to go. my petcock was so worn it was warped thats why mine didnt work. you may be ok after correct reassembly
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
- jbeebe1
28 Oct 2012 14:14 - 28 Oct 2012 14:18
No eBay APP ID and/or Cert ID defined in Kunena configurationok guys it's a no-go. I reinstalled the petcock today and wasted another 1/4 Gal of gas. Prime functions properly, but on "ON" it leaks a lot, and on "res" it leaks a little. When i suck on the vac line it leaks a whole lot, so i think the o-ring just isn't seating properly.
I'm probably going to pull the trigger on this manual one:
I'm just worried about the line coming out of the side like that and interfering with stuff.
Although it's aftermarket, i'm hoping it holds up and doesn't leak. Let me know what you think.
79 Honda CB650
81 Honda CX500
79 Honda CB650
81 Honda CX500
Last edit: 28 Oct 2012 14:18 by jbeebe1.
- jbeebe1
28 Oct 2012 14:15 - 28 Oct 2012 14:16
Sucks that I wasted 25 bucks on a rebuild kit!
79 Honda CB650
81 Honda CX500
79 Honda CB650
81 Honda CX500
Last edit: 28 Oct 2012 14:16 by jbeebe1.
- cronk
28 Oct 2012 17:29
interesting stuff. i had the opposite problem no fuel would pass. in all positions.
the round gasket with the 5 holes was mushed pretty bad blocking the passages. i've got my kit on order hoping is solves my fuel issues...
1982 KZ-550
- jbeebe1
28 Oct 2012 17:41cronk wrote: interesting stuff. i had the opposite problem no fuel would pass. in all positions.
yea, make sure your passages are nice and clear and clean and that your vac line is in good shape. Good luck
79 Honda CB650
81 Honda CX500
79 Honda CB650
81 Honda CX500
- jbeebe1
28 Oct 2012 23:02 - 29 Oct 2012 11:02
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationOk guys looks like I pulled the trigger on a manual petcock from Brown Family Racing on the Ebays. They're bought by him, then he modifies them to be better I guess, so hopefully they'll be a little better than a china petcock for a Raptor which would also fit. Thanks to Martin CSR though for the tip on using them.
I'll update once installed. Thanks for your help guys.
79 Honda CB650
81 Honda CX500
79 Honda CB650
81 Honda CX500
Last edit: 29 Oct 2012 11:02 by jbeebe1.
- jbeebe1
03 Nov 2012 17:44
I installed the new petcock today. It works great. 10x simpler than the stock vac one.Had to re-route the fuel line a little because the port comes out to the side of the new one instead of straight back, but it worked out fine.
much simpler....
much simpler....
79 Honda CB650
81 Honda CX500
79 Honda CB650
81 Honda CX500
- Kitten Tooth
03 Nov 2012 18:05
If you need a bike in the mean time you can always go out and buy one of them plastic in line valves from your local autoparts store. Will warn you though. Theres almost no way to fit it in there to look like its all stock. My hands were too big and stupid to fit between the tank and carbs to turn it on/off on my 81' KZ1000. I ended up just making my own. I got one of those little bleeder valves that they use on commercial pop machines where it has a little rod going through for the handle on the valve.
www.google.com/imgres?num=10&hl=en&safe=...s:0,i:92&tx=89&ty=47
Just like that. Me and my dad casted an aluminum mount for the tank and i drilled and tapped the holes for the valve. The line out is actually a small piece of metal brake line and the gasket that seals the mounting plate to the tank is bicycle inter tube from some old tires we had laying around.
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
