- Thank you received: 4
Gas smell - Please give me a clue.
- imon_2nd
- Architect & Engineer
26 Oct 2012 13:24 #555870
by imon_2nd
Keepin' the rubber side down.
Gas smell - Please give me a clue. was created by imon_2nd
Hello, all.
I've put over 1,000 miles on my 1997 KZ1000P since the motor and carbs were partially rebuilt. Lately, there is the smell of gas in the garage after riding. The smell must be coming from the KZ, since nothing else has been in or out of the garage. There are no seeps, damp spots, drips anywhere on the bike. Gas cap is secure. Carb gaskets are tight.
Where else should I be looking to find the source of the fumes?
Cheers,
Cheers,
- cadmonkey
- Thank you received: 1
26 Oct 2012 14:47 #555879
by cadmonkey
'82 CSR 1000 a work in progress
'97 Suzuki bandit 1200 the daily ride
Replied by cadmonkey on topic Gas smell - Please give me a clue.
based on my general mechanical knowledge....pull your air cleaner out and look in the air box. Float bowls stuck open and could be over fillng or gas tank petcock maybe stuck open. I had a float stick on my bandit once and the gas leaked out the bowl but that was obvious and visible to someone looking from 20 feet away at the side of the bike.
- imon_2nd
26 Oct 2012 15:00 - 26 Oct 2012 15:04 #555881
by imon_2nd
Replied by imon_2nd on topic Gas smell - Please give me a clue.
Thanks, cadmonkey. I'll pull the air filter and have a look. Didn't occur to me that gas could get back into the air box from the carbs.
The fumes are present whether or not I close the petcock. BTW, the petcock was cleaned and new fuel lines, new boots installed when the carbs were rebuilt in July 2012.
Cheers,
Cheers,
Last edit: 26 Oct 2012 15:04 by imon_2nd.
- gengomerpyle
- Thank you received: 17
26 Oct 2012 15:11 #555882
by gengomerpyle
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
Replied by gengomerpyle on topic Gas smell - Please give me a clue.
it might be the gas cap, how does the rubber gasket look?
1982 GPZ750R1 ELR
1971 Honda CB750K
- imon_2nd
26 Oct 2012 15:19 #555883
by imon_2nd
Hello, gengomerpyle.
Gas cap seems to seal tight -- takes a lot of pressure to squeeze it shut and locked.
Cheers,
Cheers,
- Thank you received: 2098
26 Oct 2012 15:33 #555885
by Patton
Replied by Patton on topic Gas smell - Please give me a clue.
Fuel level sending unit??
- bountyhunter
- Thank you received: 337
26 Oct 2012 16:27 #555900
by bountyhunter
Replied by bountyhunter on topic Gas smell - Please give me a clue.
It's almost always a problem with the valves/needles in the carbs or fuel levels set too high. Those valves are easy to replace and adjust height on.
- Mcdroid
- Gone Kwackers
- Thank you received: 319
26 Oct 2012 16:44 - 26 Oct 2012 16:45 #555904
by Mcdroid
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Replied by Mcdroid on topic Gas smell - Please give me a clue.
Any of the above suggestions could be the culprit...your gas cap is a venting gas cap and if you have been riding when it is warm out, then park for the evening in an enclosed space, then you could be getting a whiff of the vented air/fuel mixture.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 26 Oct 2012 16:45 by Mcdroid. Reason: clarity
