Rubber Gasket
  • poolboy
  • poolboy's Avatar Topic Author
Rubber Gasket
26 Oct 2012 13:01 - 26 Oct 2012 23:52
#555868
Having trouble with float bowl gasket. The old gasket somehow got larger "stretched, and I ordered a new one and its seems to be a little small, "shrunk that is". If I could glue the smaller one, it would stay in position long enough to install back on the carburetor. I read that someone had tried "Chapstick" and it worked, but would rather know what you guys use.
1980 KZ750H ,WG's carb rebuild, V&H 4-1 Exh ,WG wiremod, Dyna 3.0 ohm coils, Dyna-S EI DS2-2,New Bridgestones, O-ring Chain,
Last edit: 26 Oct 2012 23:52 by poolboy. Reason: clarified sentence
  • Motor Head
  • Motor Head's Avatar
Re: Rubber Gasket
27 Oct 2012 10:17
#555996
It sounds like the Gasket is an O-ring? Correct?
And the crap Deathanol fuel they force on us has reacted with the rubber in the o-ring. The new one might be dried up, or a low quality replacement. I'd order a good quality replacement and try again.
The following user(s) said Thank You: poolboy
  • baldy110
  • baldy110's Avatar
Re: Rubber Gasket
27 Oct 2012 20:39
#556040
I have goo dluck just using the swollen o-ring. I apply a little grease to get it to stick and stay put. I then work it around into the groove until it sit right.
  • jbeebe1
  • jbeebe1's Avatar
Re: Rubber Gasket
27 Oct 2012 21:28
#556049
x2 on just dabbing some grease in the groove around the perimeter and then the o-ring sticks long enough to put the bowl back on. Make sure to wipe off the grease that gets in the bowl though, you don't want that in the fuel.
79 Honda 400 Hondamatic
79 Honda CB650
81 Honda CX500
81 Honda Passport C70
others coming in and out all the time!
  • dshelly
  • dshelly's Avatar
Re: Rubber Gasket
28 Oct 2012 10:00
#556095
I know here if you run premium fuel is doesn't contain ethonol. They also make additives you can use to combat the effects of ethonol.
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
  • wireman
  • wireman's Avatar
Re: Rubber Gasket
28 Oct 2012 12:00
#556107
poolboy wrote: Having trouble with float bowl gasket. The old gasket somehow got larger "stretched, and I ordered a new one and its seems to be a little small, "shrunk that is". If I could glue the smaller one, it would stay in position long enough to install back on the carburetor. I read that someone had tried "Chapstick" and it worked, but would rather know what you guys use.
That only works on paper gaskets B)
