- Thank you received: 35
vac caps blowing off wtf?
- lushbaugh
- everybodys a pro......
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
- Del_Herring
- Thank you received: 29
1983 KZ750-N2 Spectre
- lushbaugh
- Thank you received: 2098
- Del_Herring
- OKC_Kent
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
- TheHolk
- Thank you received: 1
1978 KZ650
2009 Ducati Hypermotard
1981 Vespa P200E
- dshelly
- Thank you received: 5
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- kaw-a-holic
- Thank you received: 249
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
- taildragger1197
- Thank you received: 17
Sounds like the carbs are "sneezing" or "spitting back" at idle or off idle. This is caused by a too lean condition. You might try opening your idle air screws a 1/4 to 1/2 turn.
Could also be a problem with the ignition advance. Clean and lube it then check your timing.
Union City, Tennessee
1979 KZ1000 LTD B3
1979 KZ1000(1260)LTD S/G Pro ET
1993 ZX11 D1 Ninja
- DesertKZ
kaw-a-holic wrote: I bought my replacement caps at ACE Hardware. They are vinyl and work great.
X2, fit much snugger than the stock ones.
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
